More function keys in S3L
Hi all,
Here's some little trick to get "more" function keys: you can use Touch Strip as a "modifier" for the function keys. Create an event, set trigger operation to "AND" and add two triggers to it: 1. "Function Switch 1", "Pressed" 2. "Touchstrip Zone 1", "Pressed" Duplicate this event and change Touchstrip trigger to be "Touchstrip Zone 2", "Pressed". Duplicate this event again and change Touchstrip trigger to be "Touchstrip Zone 3", "Pressed". And the final one: "Touchstrip Zone 4", "Pressed". You used only one function key, but with help of the touch strip, you multiplied number of different events to 4. Going this way for all function keys, you can get 16*4=64 event sources by such two-finger combinations. Keep in mind, that you can press both any zone and any function key with only one hand. |
Re: More function keys in S3L
Now please, how to bring up a plugin with F key? |
Function Keys | Christoph1123 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 10-05-2020 04:06 PM |
Can't turn off Mac Function keys/turn on PTLE Shortcut keys | b mcgibney | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 11 | 09-25-2009 09:15 PM |
Function Keys on C8? | dio | ProControl, Control|24, Command|8 | 1 | 09-22-2005 08:15 AM |
FUNCTION KEYS ON 002 | dversion | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 04-26-2004 01:05 PM |
function keys don't work as quick keys | miked45 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 12-21-2003 10:32 AM |
