Old 03-16-2009, 12:31 PM
KingFish KingFish is offline
Default Shortcut for "Duplicate Backwards" ?
Highlighting a Bar of click, and hitting Cmd+D - obviously duplicates the region forward, into the timeline.
WITHOUT - converting the audio to Elastic Audio, and using the Loop TCE Tool to pull the region Back...
Is there a Shortcut to duplicate, or paste "Backward" in the timeline to "Previous Bars" ?
David
- MacStudio M1
- HDX II Sonnet xMacStudio
- 16x16 HD i/o x 6
- PT ULTIMATE
- SONOMA
- ProTools Dock / S1 / Control App
Old 03-16-2009, 12:46 PM
cneal92's Avatar
cneal92 cneal92 is offline
Default Re: Shortcut for "Duplicate Backwards" ?
Cmd-Opt-Ctrl-click the region. This will copy and place the copied region's end butted up against the beginning of the copied region.
Chris Neal :: South Plains College
.: Program Coordinator & Asst. Professor in Sound Technology
.: [email protected]
.: Pro Tools Certified Instructor
.: Pro Tools Expert Certified in Music
Old 03-16-2009, 01:27 PM
Drew Mazurek's Avatar
Just to clarify, you must have the Grabber (hand tool) selected for this to work.
www.drewmazurek.com
Old 03-16-2009, 05:51 PM
Seriously brilliant - all these years... never knew that one - Works in "Grabber Mode" of the Multi-Tool as well !! thanks guys
David
- MacStudio M1
- 16x16 HD i/o x 6
- PT ULTIMATE
- SONOMA
Old 03-16-2009, 06:12 PM
barismanco123 barismanco123 is offline
Thats not really duplicating backwards butted up to the region in the real sense of the what he is asking for (correct me if I'm wrong).
It's really spotting the region to the edit cursor which I assume is in the same place as the playback head.
Try unlinking timeline and edit and then put the edit cursor 5 bars back or forward in time and see what happens.The region will butt to there.
There is no duplicate backwards command in the real sense but have wished there was many times.
This method works most of the time but just be aware that it's a work around.
Baris
PTLE8 with an Mbox 2, for now!
Old 04-01-2009, 04:09 AM
mhmh mhmh is offline
Baris
I have a different workaround for this one, which works with selections as well: Just select the region(s) or the selection you want to duplicate backwards, hit "K" as many times as you want duplicates and then cmd-D to fill it up again. Fastest way for me.
Cheers, Martin
Mac Pro 2,4 GHz 12-Core Intel Xeon (Westmere) 32 GB RAM, OSX 10.10.5, HD I/O 16x16 analog, HD I/O 16x16 digital, 192, PT HDX2, PT HD 12.6.0
http://www.pelhamundhaas.de/index2.html
http://www.pelhamundhaas.de/vita.html
www.3-p.de
www.imglashaus.de
Old 04-01-2009, 07:58 AM
Yeah thats a good one - I wonder if there is a way around it when timeline and edit are unlinked?
I will make a feature request for duplicating backwards.
Baris
Old 04-15-2009, 10:26 PM
Cheers, Martin
Hmm... that's interesting... what IS "K" actually doing? I don't know all my command Focus shortcuts, but it seems as though it's "Moving selection back it's length"
What's the "Command Name" for this??
David
- MacStudio M1
- 16x16 HD i/o x 6
- PT ULTIMATE
- SONOMA
Old 04-15-2009, 10:53 PM
I have no idea, but "moving selection back it's length" would be my best guess, too.
www.3-p.de
www.imglashaus.de
Old 04-15-2009, 11:18 PM
nod25 nod25 is offline
Snap end (of selected region) to Playhead (HD systems only).
Difference between "Go to Song Start" and "Return to start of session" shortcut pericoloso Pro Tools 10 2 09-22-2013 12:44 AM
Consolidate vs Duplicate - "Stereo" vs. Dual Mono Behaviour rnd 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 06-05-2013 01:03 AM
"Some regions invalid bounds and were adjusted or deleted" A duplicate Audio Folder ! acmost Pro Tools 9 0 11-13-2010 05:40 AM
Whats the shortcut to duplicate backwards kevin001 Pro Tools TDM Systems (Mac) 7 06-06-2010 10:18 AM
long time problem with "duplicate" keyboard shortcut Phototropic 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 15 10-02-2009 02:22 PM
