Old 11-21-2002, 10:11 AM
LATablette LATablette is offline
Default Can you bounce to disk at half speed?
and if you can't, can anyone tell me of any way to get a file out of PT at half speed (I don't have the ability to play back at half speed and then record the playback externally)
any advice would be greatly appreciated.
thanks.
Old 11-21-2002, 10:55 AM
auxsend1 auxsend1 is offline
Default Re: Can you bounce to disk at half speed?
Well, you could bounce it as a stereo file, then start a new PT session, bring in the file, and mess w/ it there.
Or, if you have a 2-track editor like Sound Forge or something like that, then you could use that on the bounced file.
Old 11-21-2002, 11:05 AM
Roy Howell Roy Howell is offline
I don't believe you can Bounce at half speed, but you can play or record at half speed. For half speed play, just Shift/Spacebar. To record at half speed, Ctl/Shift/Spacebar.
So this probably won't help your situation too much.
rh music
Old 11-21-2002, 01:06 PM
Create a new stereo track and set its inputs to 2 unused busses.. instead of using a stereo buss for your mix.. assign to those same 2 busses as the new track. Arm the new track and go into half speed play (shift+spacebar) and record to the new track.
Rail
Platinum Samples
www.platinumsamples.com
Engineered Drums for BFD
Old 11-21-2002, 03:35 PM
phaseout phaseout is offline
Rail
<font size="2" face="Verdana, Arial">Good Idea!
Old 11-21-2002, 04:08 PM
Yes indeed... thanks, Rail... that opens some interesting sampling things as well. Now, if I can only try it before I get side-tracked... but, thanks.
rh music
won't you be recording at half speed as well (thus bringing it back to normal speed during regular playback)? --or am I missing something?
Old 11-21-2002, 06:13 PM
LATablette
You are indeed correct.. I just tried it here...
I was under the impression it would work like on a TDM system, where if I VSO the track and record - it would maintain the sample rate change.
A work around is to record or bounce the file down.. then use a utility to change the header sample rate externally to half the sample rate of the original sound file, then import it back into Pro Tools.
Sorry.
Rail
Platinum Samples
Old 11-21-2002, 08:34 PM
Well, like a fool, I tried it before re-reading this thread... too bad...same speed as before.
One thing I have done regarding half speed in PT, is to record say simple, long guitar notes while the rest of the mix is at half speed. So, it's simply the 'chipmunk' way, but it can bring very nice results, rather like a Mandolin/Strat sound. But, the simpler it's played, the better.
rh music
make a bounce on half speed.. montreal 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 25 08-27-2018 05:29 PM
Bounce to disk speed VRX Tips & Tricks 5 01-23-2006 07:49 AM
Can you bounce in Half speed electronicnoise 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 10-27-2004 08:43 AM
Bounce at Half Speed torquemada 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 09-26-2004 01:21 PM
Bounce to Disk at half speed? SteveGarman Pro Tools TDM Systems (Mac) 3 07-29-2004 07:11 PM
