I am just learning to use custom mapping with my newly arrived S1. One thing I have not worked out yet is with Softube's Console 1 channel strip and mapping buttons.
When selecting INSERT on the S1 and then navigating to Page 3 which displays the EQ parameters, it is actually laid out how I want it. But when selecting EQ on the S1 - the layout is similar but has different assignments for the buttons. For example Knob 1 on INSERT / Page 3 controls Low Gain with IN switching the channel EQ in and out - perfect. Knob 1 on EQ Page 1 controls Low Gain but IN controls shelf and bell curves. So I've tried to copy the INSERT Page 3 layout to a custom map for EQ but I can't find the EQ in and out parameter to assign?
Pro Tools Ultimate 2022.7.0 | Eucon 2022.9 | Mac OS 11.6 | Lynx Hilo |
Insert options are up to the manufacturer.
EQ options are defined by Avid for EQ. They won't all be the same. You should just use Inserts. There's an option in Eucontrol specifically for this problem on General tab. "Show EQ/DYN plug ins on surface as Inserts..." Check the box.
Pro Tools Ult 2022.7, HDX 3, MTRX/SPQ, HD Omni • S1 x 2, FireHD x 2, Dock, iPad • Mac Pro 5,1 - 3.06 GHz 12 core - macOS 10.13.6 • RAM 64GB, SSD 4 x 4TB, GPU GTX 980 4GB Pro Tools Ult 2022.12, RME BBF Pro • Mac Mini 14,12 - 12 core - macOS 13.2 • RAM 32GB, SSD 4TB, GPU 19 core |
![]() Quote:
If I understand you correctly, if I create a custom map in Inserts and then check the "Show EQ/DYN plug ins on surface as Inserts" preference my Insert custom map will show when i press the EQ button on the S1?
![]() Quote:
If you have a custom map, when you select the plugin, the Channel Tab will auto go to Insert (with the custom map) instead of EQ -- which gives you more options than EQ.
Got it thanks.
S1 Custom Mapping not working | traksion | Avid S1, S3, Dock and Control App | 4 | 07-25-2021 10:31 PM |
S1 custom mapping FF-Q3 | Frank Kruse | Avid S1, S3, Dock and Control App | 6 | 07-21-2021 08:57 PM |
Custom plugin mapping | marsian | Avid S1, S3, Dock and Control App | 2 | 05-29-2019 08:45 AM |
AVID please help! Updated to Eucon 3.3.2 and all my custom mapping GONE! | bobbyguelz | Artist Series | 0 | 01-07-2016 05:46 PM |
Mapping to custom faders | dunebuggy | Pro Tools 10 | 4 | 06-29-2015 09:51 AM |
