Go Back   Avid Pro Audio Community > Legacy Products > Pro Tools M-Powered (Mac)
Old 02-15-2016, 07:34 PM
wildplum wildplum is offline
Default older Mac, new Behringer BCF2000
I am trying to help a friend set up an older Mac to use with a BCF2000.
MacBook (from 2011, I think)
OS X 10.6.8
Pro Tools 8
Interface: M-Audio ProFire Lightbridge
The BCF2000 is brand new, ver 1.10
Pro Tools does seem to recognize the BCF2000. It is listed under Setup-Midi Devices. The problem is, however, when I go to Setup-Preferences, there is no option for the BCF2000, the only option is "none".
Any help would be most appreciated. Thanks.
Paul Tumolo
Wildplum Recordings
a micro label, studio and remote recording service
Old 02-18-2016, 11:44 AM
Default Re: older Mac, new Behringer BCF2000
I may be wrong, but I think you are in the wrong place to setup the unit. Go into Peripherals>Midi Controllers and enable it as a HUI device
Old 03-13-2016, 04:26 PM
newfuturevintage newfuturevintage is offline
this is the ticket, also, make sure you're running the BCF2000 in HUI mode. this is done by powering the unit on with either the 4th or 5th top most button pressed until the unit says "HUI". Don't recall at the moment which button. One is HUI, the other is mackie control for Sonar.
another consideration is making sure the BCF's MIDI mode is correct. I had trouble with mine using their native USB mode and ended up needing to change to wired MIDI and external MIDI interfaces.
lastly, don't try to use this as a controller + MIDI interface. In spite of there being a mode that supports it, most reports I've seen from folks trying it are not positive.
PT 7.1LE, 002 & Behringer BCF2000 pdryan 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 08-26-2008 09:19 AM
Behringer BCF2000 catalin rasvan Pro Tools M-Powered (Win) 5 11-21-2006 04:18 AM
BEHRINGER BCF2000 osturinn Pro Tools M-Powered (Win) 1 04-12-2006 11:28 AM
Behringer BCF2000 benunh 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 34 09-26-2005 07:47 PM
Anyone using the Behringer BCF2000? JCBigler 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 03-31-2005 10:43 AM
