Old 02-28-2008, 09:50 AM
wildplum wildplum is offline
Default project mix as independent mixer and interface
Interesting title, no?
Is it possible to use the Project mix as a mixer (controlling levels, eq and mutes, for example) while at the same time using it separately as an interface, sending the inputs to PT-M directly after the input gain but before the mutes, fader and eq changes. another way to put this is can i send direct outs (in some fashion)to PT-M while using Project Mix as a "live" mixer? thanks for the help.
Paul Tumolo
Wildplum Recordings
a micro label, studio and remote recording service
Old 02-28-2008, 10:50 AM
TechKnowledgy TechKnowledgy is offline
Default a
The Project Mix is not a mixer, it's an integrated control surface and audio interface. It doesn't have any mutes or EQ's built in. All the faders and knobs on the PMIX just send data to control Pro Tools and don't have any direct effect on the signal going into the computer.
Can you use an 003 Rack as your LE interface, and a Project Mix I/O for the CS? Skitch Bryant 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 07-20-2010 07:37 AM
how do I copy the mixer settings to another project? joethevan 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 04-03-2007 07:40 PM
digidesign project 2 with 442 interface??? Phil Shenton Digidesign Hardware & Software 2 08-21-2004 11:09 AM
Mixer Needed for Album Project - Pros Only RobSoul General Discussion 8 07-28-2001 12:22 AM
1622 Interface and Project II? ACIDCHAOS3 Pro Tools TDM Systems (Mac) 3 10-26-1999 06:55 PM
