VST load
Hello I have protools 2018.1. I have other applications (including cubase) with directories for VST plugins in 32 bits and 64 bits in protools how can I add in protools that directories to locate the VST from for there? For example cubase has a plug-in manager in protools is there something similar or can I run the VST plugins in protools from that directories that I share with other applications.
Thank you |
Re: VST load
No VST plug-in can run directly in Pro Tools, only AAX and, since PT 11, only AAX64. See if your third party plug-ins have AAX64 versions, or, if not, use something like Blue Cat Audio's Patchwork.
Re: VST load
oh ok I understand. I bought protools two weeks ago.
I will check blue cat. Thank you |
Re: VST load
You shouldn't need Blue Cat Patchwork as most plugins support the major plugin formats like vst2, au (Mac only) and aax 64 (PT only).
Re: VST load
Which is why I advised: "See if your third party plug-ins have AAX64 versions".
Re: VST load
I use SoundRadix 32 Lives and Blue Cat Patchwork with no problems at all running some of my legacy 32bit AU or VST plugins in pro tools.
iMac 27" Late 2013 3.5Ghz i7 32GB Ram 3TB HDD, 1TB SSD Samsung 850 Pro, Movaje 10.14.6, Pro tools 2021.7, 2021.3 & 2020.12 installed. UAD Apollo 8 Quad & Satellite Quad, Reason 10.4.1 & Reason Suite 11.3.9, Logic Pro X 10.5.1 (need to upgrade to Catalina for LPX10.6), plugins & VI's by practically everyone. G-Tech Mini 1TB HDD, 3 x 1TB Glyph GT050Q, Lacie Rugged 500GB & several assorted drives.....lots & lots of hardware synths & outboard https://soundcloud.com/2b3productions |
Pro Tools 10 not load plugins,freezing load.HELP | javierboz | Windows | 2 | 11-08-2012 04:25 AM |
PT8 won't load WTF | jonslaten | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 04-16-2009 11:53 AM |
Load LE on PC until I get a Mac? | dminorsound | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 10-17-2006 10:31 AM |
Norton Disk Doctor... to load or not to load | MixMonster | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 10 | 04-05-2004 11:25 AM |
Cpu Load vs. System Load | apetrocelli | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 09-06-2002 10:54 AM |
