What buffersize for this session?
Hoping this is the right subforum.
Next wednesday I am going to record a small acoustic band of three persons. I will be using an SM57 for the acoustic guitar, an SM58 for the singer and a Beyerdynamic M88 for the percussion. Plus that I am going to use my two Audiotecnika's for capturing the whole of them. Five tracks alltogether, I want to record in 96 KHz/24 bits. Any recommendations for the buffersize? Last year I was recording one sinhle mic at 1024 and after 30 minutes Pro Tools stopped and gave me an errormessage. This will be a very different situation and I don't want to have PT stop during the recording. Anyone? Verstuurd vanaf mijn SM-G903F met Tapatalk
Mac Book Pro 2016 Retina, Quad core i7, 2,5 GHz, 16 Gb 1600 MHz RAM, 256 SSD drive, 500 Gb SSD USB3 OSX Sierra 10.12.5, PT 12.7.1, UVI Falcon 1.6 Metric Halo ULN8 3D Interface, NI Komplete Control S49 midikeyboard Macbook Pro M1, 2.5 GHz 8 core CPU, 32 Gb RAM, 1Tb storage, Monterey 12.6.6. PT Ultimate 2023.6, UVI Falcon 3.0 + some soundbanks, Waves Platinum bundle, some free Melda plugz, Metric Halo/Make Believe plugz. |
Re: What buffersize for this session?
HI, Not a lot of deals about your system. I am on a Mac, but I have lot's of RAM. Are you using fast HD's or disk caching. Maybe reduce your individual take lengths, might be helpful. Make sure if you have latency issues or are hearing them, reduce the 1024, which I only use for mixing to a lower buffer size. 512 or 256 should work fine for simple tracking of instruments if you are even using a lot of plugins.
Composer/Sound Designer/Protools 2024.3 Ultimate, MTRXII-TB3, DADMAN MOM, Cisco SG350-10MP EthernetHUB, KLANG:quelle 4 Channel Dante™Headphone Amp, DVS,MADI, Mac Studio Ultra,128 RAM/4TB SSD, Ventura 13.6.6, DP 11.3.1, Logic Pro X 10.8.1 DOLBY ATMOS Facility/MPSE Motion Picture Sound Editors Avid Certified Professional ProTools/Dolby ATMOS |
Do I understand correctly that smaller buffersizes are recommended for this kind of sessions? I also don't know what disk caching means but my harddrive is certainly not HD. It is an internal SSD drive (250 Gb). Verstuurd vanaf mijn SM-G903F met Tapatalk
Things to consider:
#1-do you NEED 96K? It will tax the computer double of what a 48K session will, plus it will use double the drive space(and a single 250GB is not a "large" drive) #2-higher buffer=higher latency(assuming you are monitoring from Pro Tools). Lower buffer=lower latency(desirable for tracking). I track full bands at the 64 buffer at 48K(a 96K session would likely only go down to a 128 buffer, but that is essentially the same latency as 48K@64 buffer) #3-what plugins do you plan to track with(if any)? I track with EQ III 7-band, BF 76, Avid Channel Strip and plenty of others, but I pay close attention to plugin latency and ADC. While tracking, I don't use any plugin that reports more than 7 samples of latency(ADC for 7 samples is so slight that nobody wearing headphones can tell) Assuming plenty of open space on the SSD, try to keep plugin use light and the buffer low(64-128). I suggest you create a tracking session before the players arrive and put all tracks in record, and let it run for 5 minutes so you know that the computer will handle it(it sucks to find out it won't with clients in the room).
Ok 96KHz might be a bit exaggerated, I'll go for 48. Thought I might as well go for the extra quality but it puts a strain on the computer. So now I'll need a buffer of 64.
During tracking I have no plugs. In the mixdown process I think I'll need 5 EQ's and 5 comps plus one reverb at most. This kind of session must be a piece of cake for my rig. Oh and, I will do a test recording before the band arrives, so there will be no embarrassing situations. Albee1952 & gives, thanks for answering Think there will be not many serious probs @ 48 KHz
Hmmmm I created a session at 48 KHz, 24 bit and set the buffer to 64. Tried to do a testrecording with 5 tracks record enabled and got the CPU overload plus a recommendation to increase the buffersize. I did and now it works fine with the buffer on 1024 samples.
Now it was easy to find that out and it works, but I can't rhyme this with Albee1952's advice. No big deal but what if things are getting really complicated and difficult? Anyways, 48 KHz probly saves me most of the difficulties.
What are the specs of the Macbook? And, have you done all the required system tweaks(that's step #1). Moving on, you never mentioned what interface you have? Do you have the latest driver for the interface? I'm not a Mac guru so I'm afraid I won't be much help moving forward. You might also try recording in Garageband to see if its easier on the computer
As far as system tweaks, never done them. I know there is a list of tweaks for Windows, but never knew about OSX tweaks. I'll dive into that later, sounds very interesting. 23.45 h here, close to midnight. I'll check out all the requirements later on. Thank you so far Verstuurd vanaf mijn SM-G903F met Tapatalk
Sorry! Guess I need new glasses or more caffeine! Is that i7 a dual core or quad? A quad should have an easy time with a small session like you described so its time to review those system tweaks. Since you are recording to the internal drive, don't connect the USB drive(it taxes the USB bus, even if its not being recorded to). Or, you might repeat the same test but run the session from the USB drive(instead of the internal). I still think a dual-core i7 should handle a small session(just thinking back to the days of my dual-core rig)
It's a quad-core. I'm checking into the system optimizations. Thanks again Albee
How to get the low H/W buffersize of 32 | Dutchmountain | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 7 | 12-18-2009 10:34 AM |
How do i change the I/O Buffersize? | One-i | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 01-15-2006 07:57 AM |
Buffersize vs RAM | soebx | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 06-01-2005 02:27 PM |
buffersize PT 6.4 ?? | hoijandee | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 05-05-2004 01:01 AM |
Native B4 and H/W buffersize 128!? | P_J | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 07-31-2001 02:06 PM |
