Originally Posted by Oliver M
One simple advice which saved my butt since years:
Keep a copy of the following files (and make sure they are in the right location) prior to installing or updating a PT version:
~/Library/Audio/MIDI Configurations/Default.mcfg
yourHD/Library/Audio/MIDI Drivers/DigidesignMIDIIODriver.plugin
The first file makes sure you use the same MIDI I/O settings, the second one needs to be in place so that it gets updated by the PT installer. If no DigidesignMIDIIODriver.plugin is present the PT installer won't update it NOR install one!!
The latest stand alone installer available is v9, yes but the PT 10 installer updates the MIDI I/O Driver to a higher build. I have no idea if it actually comes with changes but I think the newer the better?!
Thanks... PT10's installer did update v9's driver to v10.
