Update to 5.1.1 problem
Trying to update a PT system from 5.1 to 5.1.1 (or even 5.2) but the
installer quits telling me... "Pro Tools software version 5.1 is required before this installation can proceed" Well, ProTools 5.1 software is installed but it just won't see it. I tried the 5.2 updater with the same problem. I did the same upgrade on my other system without the slightest problem. Any clues would be greatly appreciated! thanks, Don [img]images/icons/confused.gif[/img] |
Re: Update to 5.1.1 problem
DonMR
The installer is seeing a non-stock install of ProTools 5.1 This can be a alternate DAE or Mixer plug-in, ProTools 5.1 cs3 or any other number of things. That easiest way to deal with this is: 1) Trash the Digidesign Folder 2) Trash the DAE folder ( You may want to remove the Plug-ins folder and Plug-ins settings folder and move them to the desktop so after you re-install and update you can just drop in those Plug-ins and settings back to the new folders created by the install and manually run the plug-ins update from the installer ) 3) System folder, trash all Digidesign Extentions and Control panel. 4) System folder, trash the ProTools preferences, Digisetup and DAE prefs folder. 5) Re-install ProTools 5.1 6) Run the 5.1.1 updater Digidesign Tech Support |
Thanks!
That did the trick perfectly. Don [img]images/icons/smile.gif[/img] |
ProFire 2626 problem on MAC and Update problem | razzor | Pro Tools M-Powered (Mac) | 4 | 04-22-2010 09:09 AM |
Problem with update PT7.0 to 7.1 | Muckeman27 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 10-08-2006 10:13 AM |
Big problem with cs8 update...HELP! | jtarbutn | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 04-14-2005 09:26 AM |
Update 5.1.1 > 5.2 problem | Bing 81 | Pro Tools TDM Systems (Mac) | 1 | 06-04-2002 11:02 PM |
PT LE5.1 - 5.1.1 update problem | dnerd | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 10-04-2001 07:55 AM |
