Old 10-04-2008, 10:08 AM
postprosound postprosound is offline
Default What changes are "under the hood" of PT8?
Digidesign,
A lot is said about the new GUI, and other things that are readily seen, but what new things are there 'under the hood' of the latest PT release?
Old 10-06-2008, 12:25 PM
DigiTechSupt's Avatar
Default Re: What changes are "under the hood" of PT8?
That would depend on how 'under the hood' you're talking about. We're always making improvements when we get the opportunity or where feature implementation dictates.
Is there something you're looking for in particular?
Avid Audio Tech Support
Support FAQ
Old 10-06-2008, 01:45 PM
lwilliam lwilliam is offline
OK...I'll bite:
1. Are there any improvements in RTAS efficiency? RTAS does have a (deserved) reputation of being less efficient than AU or VST: fewer plugins per given CPU.
2. Any improvements in multiple CPU balancing? (although I understand that the OS is a big factor in balancing across multiple CPUs - because Logic doesn't even balance across 8 CPUs well)
3. Has the waveform drawing bug been addressed?
Larry
PTLE8/002r;OS 10.6.4 2 x 2.26Ghz quadcore,6GB RAM, Waves Platinum, many other plugins...
Old 10-06-2008, 03:50 PM
The Dougfather The Dougfather is offline
Offline bouncing would be very handy?
Waveform issue resolved?
Oh, and buffer errors on first launch when using sample based VI's.
Cheers
iMac i5 2.8GHz, Macbook Pro 2.4GHz, Pro Tools 10/11, MOTU 828mk2, Presonus Digimax FS, Presonus Firestudio Project, TC Konnekt 24D
iCON Photography
Old 10-06-2008, 04:52 PM
Originally Posted by lwilliam View Post
OK...I'll bite:
1. Yes, but maybe not quite as extensive as you (or we) would like yet. It's an ongoing process and there are several factors that come into play that we don't necessarily have control over.
2. What are you seeing that causes you to question this? There should be no issues with CPU balancing beyond issues with non fully RTAS optimized code in plug-ins. That is something only plug-in manufacturers can address.
3. Yes! - I'm going to say that with the caveat that the fix has not been fully tested yet, but I can't imagine this going out without a solid fix. We're also hoping to roll this into a cs release for previous versions.
Support FAQ
Old 10-06-2008, 05:22 PM
Thanks! All good info.
Actually, PT seems to balance across my 2 G5s just fine - even with 10.4.11. I had the impression (maybe mistakenly) that the quad and 8 CPU Macs weren't balancing well across all 4/8 with PTLE. However, that MAY just be an..err..uh LP8 issue (a single CPU spiking way early, for instance).
I did read that OS 10.6 is supposed to improve load balancing across multiple cores/cpu's, so I deduced that the OS is at least a factor.
Larry
Old 10-06-2008, 07:06 PM
RockGod RockGod is offline
Glad to know it's not just me who gets these buffer errors. Seems strange how they only occur on the first playback attempt after loading a session. It's easy to work around but a fix would be great
2x 2.8GHz Quad-Core 2008 Mac Pro: OS 10.5.5: 6GB RAM: 003 Console: Pro Tools 7.4.2
Old 10-07-2008, 02:02 PM
myfavedave myfavedave is offline
I seem to have problems using all 8 processors in my Mac Pro 8 core (10GB RAM). The performance is worse than when set to 1 processor!
I currently have it set to 7 and it seems ok, but still spikes randomly.
Is this just me?
Old 10-07-2008, 02:15 PM
Is this just me?
No, it's the same for me
Does "Westmere" qualification apply to "Bloomfield" and "Gulftown" also? bashville Pro Tools 10 5 03-23-2013 04:04 PM
Pro Tools 9 "Pausing" when I press "Play" with Focusrite Scarlett interface eanderso22304 macOS 3 11-23-2011 07:45 AM
hardware buttons for "preview", "capture" and "punch" evs Post - Surround - Video 1 12-06-2010 01:28 PM
What changes are "under the hood" of PT8? postprosound Pro Tools TDM Systems (Mac) 5 10-04-2008 05:21 PM
The "FATE" of CM LABS "MotorMix" & "MotorMate". Dum dum dum dum... leon777 Pro Tools TDM Systems (Mac) 21 10-15-2002 01:00 AM
