  #261
Old 12-07-2010, 09:07 AM
Arno Peeters's Avatar
Arno Peeters Arno Peeters is offline
Default Re: NEW UPDATED Room Calibration for Film and TV Post
In the A/85, Annex D, I read:
"Put a sound level meter at the position of the center of the head of the normal position for the operator, pointing it at the loudspeaker channel in use. "
But in this test from RealTraps it reads:
"Although omnidirectional microphones supposedly receive sound equally from all directions, when measuring rooms and loudspeakers the convention is to "aim" the microphone upward. No omni microphone has exactly the same frequency response from all directions, though microphones with tiny diaphragms and slim bodies are often more uniform than larger models. So when balancing loudspeaker volume levels on a surround system, pointing the microphone toward the ceiling favors all of the loudspeakers equally."
What's your take on this?
And another question about bass-management: is it possible to adequately mimic it's effect within PT (with routing and eq), according to it's diagram?
Arno Peeters
Tape TV Productions
  #262
Old 02-28-2011, 11:12 AM
Eric Seaberg's Avatar
Eric Seaberg Eric Seaberg is offline
We've got a Sencore test set for our monitors as well as the Genelec DSP system. For both setups, Genelec DSP and non-DSP, I do point the mics straight up with the diaphragm close to ear level. The level and test results are very consistent for both measuring microphones.
Eric Seaberg • San Diego, CA
A.E.S., I.E.E.E., S.M.P.T.E., S.P.A.R.S.
  #263
Old 03-06-2011, 04:31 PM
SDDP SDDP is offline
If I'm not mistaken, technically on paper this sounds correct, but throw in the Psychoacoustics of our ears design, I think it be best to mimic our ear and have the mic pointed straight at the center speaker at ear level. In that way we are calibrating to how the mixer at the mixing position would hear and thus make his decisions.
  #264
Old 05-02-2011, 02:11 PM
danijel danijel is offline
Originally Posted by dr sound View Post
Read the Blue Sky set up FAQ on the page
http://www.abluesky.com/asp/catalogu...asp?linkid=172
Marti, looks like the Blue Sky re-worked their web. Here is the new link:
http://abluesky.com/support/blue-sky...on-test-files/
Danijel Milosevic
  #265
Old 05-02-2011, 02:42 PM
dr sound's Avatar
dr sound dr sound is offline
Danijel,
Thanks for the heads up. The Updated "Room Calibration..."
has the new link.
Marti D. Humphrey CAS
aka dr.sound
www.thedubstage.com
IMDB http://www.imdb.com/name/nm0401937/
Like everything in life, there are no guarantees just opportunities.
  #266
Old 05-30-2011, 11:49 AM
zzstation zzstation is offline
I've just downloaded the BlueSky files to calibrate my room once again.
It is a small room.
My only doubt is if I point my Radio Shack to each speaker at time. Or if I always point the mic to the center while panning the pink noise to the others speaker.
Thankk,
ZZstation
  #267
Old 05-31-2011, 10:00 AM
dr sound's Avatar
It is a small room.
Thankk,
ZZstation
I just updated the link (5-31-11) .
Please go to the new Dolby link at the top and follow the link.
This will answer your question.
aka dr.sound
www.thedubstage.com
  #268
Old 05-31-2011, 10:25 AM
jimlongo's Avatar
jimlongo jimlongo is offline
A question about that Dolby document. 3.4.3 Taking a First Measurement
3. Ensure that you are sitting in your normal, proper reference listening or mixing
position. Set the SPL meter to “C” weighting and “slow” response.
4. Facing the front speakers, hold the SPL meter at chest level, with the microphone
facing up at an angle of approximately 45 degrees to the center speaker. Keep the
meter at arm’s length to prevent measuring audio that may reflect from your body.
You should be able to take SPL readings as you look down at the meter.
5. Keep the SPL meter in this position. Make sure that the meter is aimed at the
center speaker as you take readings for the left and right speakers.
6. When taking the SPL readings for the left surround or right surround speakers,
keep the meter at the same angle and position as you did for the front speakers.
Turn your body 90 degrees from the center speaker towards the wall closest to the
surround speaker you are measuring. This will minimize “shadowing” or
obscuring the meter with your body.
#4 in a small room that measurement can be awfully close to the monitors. I've always put the meter on a stand and positioned it right about where my head would be. What do you think? Again in a small room armslength puts the meter closer to the front than the L-R, and is off angle to the L-R.
#6 when they say "same angle and position" I take that as meaning "relative to your body"? IOW 2 feet from center, facing the surround side.
noise | jimlongo
  #269
Old 06-01-2011, 08:05 AM
Great! Thanks, Marti!
  #270
Old 06-11-2011, 11:58 AM
Charles Deenen Charles Deenen is offline
btw, once again, the dolby document does not work well for small rooms. (marti, no need to comment, I know you don't agree). They only work for small rooms with wide dispersion speakers (and at least 10 foot of space between listening spot and speakers), which most small rooms from what I've seen won't be using.
The rules dramatically change once your speakers are less than 8 feet away, and are 45 degree or more spread out from listening position.
This is the guidelines that we're using at our company, and they translate well. Use at will, or ignore. It doesn't matter to me :)
http://www.cdeenen.com/Charles_Biz/T...n_Vid_Game.pdf
HTML code is On
Room Calibration - ATSC Standards - Help mikevarela Post - Surround - Video 20 08-29-2013 09:26 AM
D-Control output calibration for film... Pete@twenty7pix ICON & C|24 2 02-28-2011 10:10 PM
Meters for room calibration idris Post - Surround - Video 3 09-23-2010 05:27 PM
Calibration in a small room... joeyk Post - Surround - Video 3 05-08-2006 10:02 PM
Room Calibration and Levels for LE Starcrash Post - Surround - Video 8 08-03-2005 10:40 AM
