Old 06-25-2019, 07:59 AM
sneakyimp sneakyimp is offline
Default possibly corrupt 002 driver? Dead 002 unit?
I've been running protools 9.06 on a Windows 7 box with a digi 002 interface for years. A few days ago, after cleaning, I tried to run protools and it complained it couldn't find the hardware. After trying various things (including running the installer for the 002/003 drivers), I plugged in a Digi 003R+ and then yesterday I tried a Digi 003R and both of these devices seem to work.
I'm wondering if the Digi 002 is maybe dead after all this time? Or perhaps the driver got corrupted somehow? I see that the 002 drivers are still kicking around inside the machine when I try to choose an audio device in Reason (see attached image) but I cannot get the 002 to show up in the windows device manager even if I do the set devmgr_show_nonpresent_devices=1 trick before launching the device manager.
Can anyone tell me what steps to take to determine if this 002 is dead? Seems to me I should delete the 002 drivers and reinstall them. Sadly, I can't get these drivers to appear in the device manager so I can click 'uninstall'. I'd also point out that the 1394 lights on the front of the 002 never light up, but the link light right next to the firewire connector lights up just fine.
Old 06-25-2019, 03:53 PM
Default Re: possibly corrupt 002 driver? Dead 002 unit?
****WARNING**** DO NOT HOT-PATCH firewire on 002 or 003. It can(and usually WILL) fry the FW circuit Everything should be OFF when connecting of disconnecting the interface.
Its probably NOT a driver issue(002 and 003 use the same driver). Make sure you have the proper driver for rack version vs. mixer version. Are you aware of the "Power Harness Issue"? Its well documented and almost every 002 will suffer(except for the very last batch maybe). What often brings the 002 back to life is simply reseating all the power harness connections inside the unit. Do this with the 002 disconnected from power! With the rack version, its really easy; pop the lid off with the unit facing you. PSU is bolted to the right side. Follow the wire harness and pull-reconnect each Molex connector 5-6 times. The mixer version is more complex as you have to flip the unit face down, remove all the bottom screws, lift the panel SLOWLY(the PSU is bolted to the bottom). The mixer version has one more connection that is under the PCB that holds the MIDI and FW jacks. Removing several phillips screws allows that PCB to lift for access. If none of this helps, it may well be dead
Old 06-28-2019, 04:46 PM
Thanks for this warning. I was aware.
Just to be clear, the green light right labeled LINK right next to the firewire port on the back of the 002 turns on when it is connected to a running computer. HOWEVER, the 1394 light on the front of the 002 does not ever turn on.
The 002 worked for years so I presumably had the right driver in it. I am concerned that this driver might have become corrupted. I want to know how to remove the driver and reinstall it fresh. Right now, I have a 003 plugged into the computer and it's working just fine.
I am vaguely aware of the power harness issue and I've taken the bottom off the unit (it's a console, not a rack unit) and I have unplugged and re-plugged some power connections. This did not seem to help. I'd also point out again that the LINK light right next to the firewire ports on the unit lights up when a firewire cable is connecting it to a running computer. Would the wiring harness problem prevent this light from coming on? Is there no way to diagnose whether the firewire chip/board in the machine might be fried?
So are you saying that after removing all those many screws to get the bottom off, I still need to detach a printed circuit board? Is there some video or detailed description of this?
I bought a 003 to replace this unit and expect I'll get rid of the 002, but I want to know if it's toast before trying to sell it or whatever.
Old 06-28-2019, 05:24 PM
There are 5 total connections to exercise. the one feeding AC to the PSU(2 wires) going out of the PSU and 3 connections on circuit boards. The one you don't see is the one feeding the board with the firewire on it, so its worth a go
MC524 PSU possibly dead MarcOFB System 5 0 02-25-2019 11:04 AM
Blue Screen Windows 7 - 003R Driver Crashing Possibly blizzard Windows 36 02-13-2016 01:31 PM
mBoxMini3 no longer detected + phantom not coming on: is the unit DEAD? orlando74 Windows 5 07-26-2013 03:13 PM
Dead ProControl Main Unit Jim Roberts ProControl, Control|24, Command|8 18 08-10-2012 08:29 AM
NEED HELP installing wave driver and possibly more ryanstack 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 09-01-2004 11:15 AM
