Go Back   Avid Pro Audio Community > Pro Tools Software > Pro Tools | First Discussion
Old 06-04-2019, 09:24 PM
Jakeman Jakeman is offline
Default HUI Control Surface and PT First 2019.5
I just downloaded the update for ProTools First v2019.5
I would now like to get my Mackie Control Universal to connect but don't see where to do that in PT First. And yes I know v2018 didn't have the ability for control surfaces, but version 2019.5 should according the the Avid comparison page. What am I doing wrong or did Avid make a mistake in the online documentation?
Here is a screen shot of the comparison of each ProTools versions.
http://duc.avid.com/attachment.php?a...1&d=1559708265
File Type: jpg Screen Shot 2019-06-04 at 10.06.50 PM.jpg (48.0 KB, 0 views)
Old 06-05-2019, 04:29 AM
ChuckS ChuckS is offline
Default Re: HUI Control Surface and PT First 2019.5
If it's available in that version it would be under Setup --> Peripherals --> MIDI Controllers. You'd need to have the MCU set for HUI mode if available. Not familiar enough with the MCU to know if that's possible.
PT 2019.6 DP 10.01 VEP 7.x Komplete Audio6 HP Envy 8G i7 Quad Laptop Win10 (x64 1909)
PT 2019.6 DP 10.01 VEP 7.x 828mkII ADA8200 MTP-AV 2011 Mac Mini i7 Quad High Sierra.6
Old 06-05-2019, 07:45 AM
There is no Peripherals under Setup, that's the first place I looked.
I've had my MCU setup for years on my older PT 8 HD rig. The MCU has been loosing connection there so thought I'd see if it would work on PT First now that HUI-Compatible Control Surface is now showing as supported.
Thanks for the help though.
Jd
Old 06-06-2019, 12:38 AM
RecordingStudio9 RecordingStudio9 is offline
I'm sure, like many options missing in the PTF, web site is not updated or someone put the detail on the web without checking, as previously HUI is not supported.
Old 06-06-2019, 04:46 AM
junkgear's Avatar
junkgear junkgear is offline
Hang tight, I'm trying to get an official answer on this.
Will K
System Details
Old 06-08-2019, 12:07 AM
Thanks!!!
Jd
Old 06-09-2019, 04:56 PM
DigiTechSupt's Avatar
Originally Posted by Jakeman View Post
Thanks!!!
Jd
Hi Jakeman, sorry, HUI and Eucon are not supported on Pro Tools First. Peripherals are not available on this free DAW. I've forwarded the concern to the team to correct the info on the website.
Thanks,
Tope
Avid Audio Tech Support
Support FAQ
Old 06-09-2019, 09:55 PM
Thanks,
Tope
Thanks for the inquiry. I thought it was to got to be true, and thus it was.
Jd
2019.5 PT Control app Monitoring Page paulo m Pro Tools 2019 0 05-09-2019 05:40 PM
003 control surface (As audio) & control 24 as surface crizdee ProControl, Control|24, Command|8 7 01-04-2016 12:30 PM
Control Surface For Protools 10 Mackie Pro Control or Avid Artist Control lberrios1962 Pro Tools 10 18 05-26-2012 12:51 AM
D-Control Es32 Control Surface No Sound from Headphone outputs mark007 Pro Tools TDM Systems (Mac) 0 02-08-2012 07:03 PM
Mackie Control Universal or Tascam 1082 for control surface? anders Pro Tools TDM Systems (Mac) 5 05-28-2007 06:12 AM
