Go Back   Avid Pro Audio Community > Pro Tools Hardware > FireWire and USB Audio Interfaces (Mac)
Old 08-11-2016, 01:38 PM
Boxy-M Boxy-M is offline
Default Re: Mbox 3 - audio dropouts or audio loop..
What should I do?
Laptop:
MacBook Pro (13-inch, mid-2012)
Processor 2,5 GHz Intel Core i5
Memory 4 Go 1600 MHz DDR3
Graphism Intel HD Graphics 4000 1536 Mo
OS: Mac OS X El Capitan 10.11.5
Audio Interface: Mbox 3
Software: Ableton Live 9
Old 08-11-2016, 01:41 PM
Top Jimmy's Avatar
Default Mbox 3 - audio dropouts or audio loop..
Originally Posted by Boxy-M View Post
What should I do?
Manually delete everything. Don't worry about it if one of the files listed isn't installed on your system. Empty trash. Reboot. Install older driver.
The Mbox isn't a FireWire interface so no surprise those files aren't there.
James Cadwallader
Hackintosh - Gigabyte Z77X-UP5TH, Intel Core i7-3770K, 32GB 1600Mhz DDR3, 2x SATA 6Gb/s 240GB SSD, 3x SATA 6Gb/s 1TB HDD, 1x Glyph 2TB USB3 HDD, Sierra 10.12.6.
Pro Tools HD 2018.12, Focusrite Red 8Pre, Mbox 3 (Mac)
Pro Tools 11.3.2, Mbox2 (Win 7)
Old 08-11-2016, 02:19 PM
I manually deleted everything listed. Empty trash. Reboot. Install older driver.
The problem is still here, the audio dropped out after 5 minutes..
Laptop:
Old 08-11-2016, 02:38 PM
Top Jimmy's Avatar
How old was the last working driver? I would try going back to that one. Also try a different usb cable and port.
James Cadwallader
Old 08-11-2016, 02:51 PM
I think it was the 1.2.3 driver version, not sure. I'm going back to this version and I'm going to try a different usb cable/port.
Laptop:
  #16
Old 08-11-2016, 02:56 PM
The Mbox 3 is not recognised when using the 1.2.3 driver version..
Laptop:
  #17
Old 08-11-2016, 03:09 PM
Top Jimmy's Avatar
Oh poo. That probably means the firmware got updated.
James Cadwallader
  #18
Old 08-11-2016, 03:10 PM
:/... What should I do then?
Laptop:
  #19
Old 08-11-2016, 03:13 PM
Top Jimmy's Avatar
I don't know if the firmware can be regressed or reflashed in the field. What firmware version is listed in the Mbox control panel?
James Cadwallader
  #20
Old 08-11-2016, 03:14 PM
There is none. It's written :" Package: 1.2.3, Firmware: "
Laptop:
Audio dropouts with BX5A monitors through Mbox 2 toddamo 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 13 01-04-2010 10:43 AM
mbox + Coreaudio 7.4.2 and OSX10.5.7 audio dropouts eddiepratt 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 06-05-2009 12:59 PM
massive audio dropouts, Mbox 2, Athlon 64 X2 4800+ P Heist 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 12-10-2005 03:47 PM
Mbox audio dropouts bootsy_collins84 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 12-10-2005 12:08 PM
Mbox audio dropouts rgeary 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 11-20-2005 01:07 AM
