Go Back   Avid Pro Audio Community > Pro Tools Hardware > FireWire and USB Audio Interfaces (Mac)
Old 08-10-2016, 10:14 AM
Boxy-M Boxy-M is offline
Default Mbox 3 - audio dropouts or audio loop..
I got audio dropouts every 5 or 10 minutes using my mbox 3. Sometime the audio loops and it won't stop until I disconnect the box.
I'm on ableton live (latest version). I've been using this configuration for several years - never had any problem.
The problem appeared at the same time I installed the latest driver from this page : http://avid.force.com/pkb/articles/e...d/Mbox-Drivers
My mbox 3 is pretty much unusable..
What can be done to fix this problem?
Thanks in advance!
Old 08-10-2016, 11:01 AM
JoelG's Avatar
JoelG JoelG is offline
Default Re: Mbox 3 - audio dropouts or audio loop..
Can you provide your full system specs? http://duc.avid.com/showthread.php?t=300050
Make sure you go through the Optimization Guide for your OS, specifically anything that has to do with power saving.
Joel
Jame Space:
HP Elite 6300 / Core i5 3570 / 12GB RAM / Win 10 Pro
Pro Tools 12 HD / Focusrite 18i20 + M-Audio ProFire 2626
Home:
Intel S5000PSL / 2 x Xeon E5450 / 32GB RAM / Win 10 Pro
Pro Tools 12 HD / M-Audio Project Mix IO
Rig:
Eleven Rack / ART SLA1 / Fender Mustang V 412 / FCB1010 w/ EurekaPROM
Old 08-11-2016, 06:33 AM
Here you go:
Laptop:
MacBook Pro (13-inch, mid-2012)
Processor 2,5 GHz Intel Core i5
Memory 4 Go 1600 MHz DDR3
Graphism Intel HD Graphics 4000 1536 Mo
OS:
Mac OS X El Capitan 10.11.5
Audio Interface:
Mbox 3
Software:
Ableton Live 9
Laptop:
OS: Mac OS X El Capitan 10.11.5
Audio Interface: Mbox 3
Software: Ableton Live 9
Old 08-11-2016, 07:35 AM
JoelG's Avatar
Thanks for the info, have you gone through the Optimization Guide I had posted?
I'm a PC guy, so hopefully someone with more Mac experience can chime in, but 10.11.5 isn't officially supported for the Mbox 3, not to say it wont work:
Supports Mac OS X 10.8.5, 10.9.5, 10.10-10.10.5, 10.11.1-10.11.3
Any changes of then the driver update done to your computer around the time the issues started? Any specific reason you updated the driver?
Joel
Jame Space:
Home:
Rig:
Old 08-11-2016, 07:46 AM
I've gone through the first steps of the Optimisation Guide (energy saver, should I do all of them?).
I updated the driver for no particular reason except for having the latest driver version.
Laptop:
Old 08-11-2016, 01:06 PM
I've gone through the optimization guide and followed every single step, it hasn't fixed my problem..
Laptop:
Old 08-11-2016, 01:17 PM
Top Jimmy's Avatar
Have you tried going back to the older driver?
James Cadwallader
Hackintosh - Gigabyte Z77X-UP5TH, Intel Core i7-3770K, 32GB 1600Mhz DDR3, 2x SATA 6Gb/s 240GB SSD, 3x SATA 6Gb/s 1TB HDD, 1x Glyph 2TB USB3 HDD, Sierra 10.12.6.
Pro Tools HD 2018.12, Focusrite Red 8Pre, Mbox 3 (Mac)
Pro Tools 11.3.2, Mbox2 (Win 7)
Old 08-11-2016, 01:20 PM
No, do I need to uninstall the actual driver before? Or can I directly download to the older driver?
Laptop:
Old 08-11-2016, 01:24 PM
Top Jimmy's Avatar
You can manually uninstall by deleting the files listed for the Mbox 3.
http://avid.force.com/pkb/articles/e...nents-Mac-OS-X
James Cadwallader
Old 08-11-2016, 01:30 PM
Thanks!
There are some files missing on my computer (for example, these 2: /Library/Extensions/DigidesignFirewireHelper
/Library/Frameworks/DigidesignFWDriver
Laptop:
Audio dropouts with BX5A monitors through Mbox 2 toddamo 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 13 01-04-2010 10:43 AM
mbox + Coreaudio 7.4.2 and OSX10.5.7 audio dropouts eddiepratt 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 06-05-2009 12:59 PM
massive audio dropouts, Mbox 2, Athlon 64 X2 4800+ P Heist 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 12-10-2005 03:47 PM
Mbox audio dropouts bootsy_collins84 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 12-10-2005 12:08 PM
Mbox audio dropouts rgeary 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 11-20-2005 01:07 AM
