Old 07-06-2013, 08:05 AM
Seafoam_Green's Avatar
Seafoam_Green Seafoam_Green is offline
Default I push PLAY and Stop Button lights up Blue ???
Hi I hope someone can help ? .......,
Ive racked my brain on the manuals for hours .......,
When I press PLAY in the transport , it lights up green for a second , (and flashes once)
...., while at the same time the STOP button turns BLUE ( and also flashes 0nce )
- then they both return to white ..., and nothing happens , ie; my music wont play .
Ive tried everything , and its driving me nuts .... Why wont the play button simply "PLAY" ????????????????????????????????? Ive also tried reloading , re-starting ,etc etc
- PT - 10.3.6 , Mbox pro , windows 7 , 64 bit.
Old 07-06-2013, 08:49 AM
dr_daw's Avatar
dr_daw dr_daw is offline
Default Re: I push PLAY and Stop Button lights up Blue ???
I haven't seen too many guys with this issue in your setup. I have had this same 'play/pause' mode. To get things to work what I do is the following;
Go to the interface control (in my case Saffire MixControl)
Change the buffer size from whatever it is at, and change it back
Voila! Play/pause mode fixed
Since updating my drivers for my Saffire, I haven't had this issue since then. Good luck, search 'play/pause' mode on here you may find other users with the same issue and setup as you.
FBR recording - https://www.facebook.com/fromthebase...cordsrecording
@FBRrecording - Instagram
Rig
MBP 15" High Sierra 10.13.3, i7 2.6Ghz, 8Gb DDR, 750Gb 7200rpm, PT 2019.5, Focusrite Saffire Pro 40, Octopre MkII, Glyph GPT50, Avalon 737sp, AMS Neve 1073's, API 512c, CAPI 312's, DW drums, Fender Guitars/Amps, AKG, Rode, Sennheiser, Neumann U87 & KM184's, Coles 4038, Equator D5 monitors
Old 07-06-2013, 09:03 AM
Thanks a million
this worked a treat , you are a true scholar and a gentleman , and a champion also .
Old 07-06-2013, 09:18 AM
dr_daw's Avatar
Glad I could help, I know how frustrating these little quirks can be. Rock on!
Rig
Music won't play. Play button flashes and Stop button lights up Mattitude 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 23 04-02-2018 09:02 AM
Press PLAY and STOP button lights! ronlosangeles Pro Tools M-Powered (Win) 0 11-29-2011 10:19 AM
blue pause button lights up and failure begins! roxie-lala 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 07-23-2010 12:34 PM
Hitting Play or Record, blue stop button lights up... delay Monty_python 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 10 09-06-2009 11:33 AM
ProTools "stop" button lights up when I hit "play" andy knowles 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 6 01-20-2005 12:07 AM
