Old 03-02-2012, 07:09 PM
MattBaron MattBaron is offline
Default Unable to change sample rate or buffer size with 11R
Hi, I have an Eleven Rack and in Pro Tools 8.0.3 and when I try to change the sample rate the drop down box is greyed out and locked at 44.1kHz and when I try to change the buffer size the only option available from the drop down menu is 1024. How can I change these? Thanks in advance!
Old 03-02-2012, 07:56 PM
Top Jimmy's Avatar
Default Re: Unable to change sample rate or buffer size with 11R
If you have the 11 rack set as the default system audio device, you should change it to something else. While you can use your interface for system sound, it will conflict at times with Pro Tools.
James Cadwallader
Hackintosh - Gigabyte Z77X-UP5TH, Intel Core i7-3770K, 32GB 1600Mhz DDR3, 2x SATA 6Gb/s 240GB SSD, 3x SATA 6Gb/s 1TB HDD, 1x Glyph 2TB USB3 HDD, Sierra 10.12.6.
Pro Tools HD 2018.12, Focusrite Red 8Pre, Mbox 3 (Mac)
Pro Tools 11.3.2, Mbox2 (Win 7)
Old 03-03-2012, 03:35 PM
moff moff is offline
What's the sample rate of your ProTools project (or session)?
Old 03-03-2012, 09:26 PM
Yeah I had tried it with and without the 11R selected as the default audio device and in both cases the results were the same. As the the sample rate of the session it is 44.1kHz and when I create a new session it is the only option available to me.
Old 03-03-2012, 10:11 PM
Top Jimmy's Avatar
When changing from the default device, anything already using it would still be using it. It could be your browser, iTunes or anything. Quit any and all running programs, change the default recording and playback devices to anything else, and then try Pro Tools. If it still doesn't work, reboot and try one more time.
If that's not it, trash prefs and databases. I would also suggest you update to 8.0.5, as it solved some issues that had plagued 8.0.3 and 8.0.4. The bugs that are in 8.0.5 are less egregious.
James Cadwallader
Old 03-05-2012, 03:39 PM
I set the default audio device to something other than the 11R, restarted, and was able to change everything! Thanks so much for your help!
ProTools 8 Won't Startup, Can't change sample rate, Can't change h/w buffer size! Nickford Windows 0 05-26-2013 11:20 AM
change sample rate? RonInLA12 Pro Tools M-Powered (Win) 0 01-17-2013 07:25 PM
Can't change sample rate Gabriel_S 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 04-20-2012 11:43 AM
Change Sample Rate? kevinb511 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 08-10-2006 12:33 PM
Change sample rate??? mixerboy 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 09-19-2003 01:31 PM
