Go Back   Avid Pro Audio Community > Pro Tools Hardware > FireWire and USB Audio Interfaces (Mac)
  #21
Old 11-04-2013, 09:58 AM
Default Re: DYI I guess..No power on your new Mbox Pro 3? I fixed it!!!
Originally Posted by versechorusjvh View Post
I was having a similar issue, opened it up and one side of the IDE cable wasn't seated properly, I reseated it, now it still won't power up, however two little red LED lights on the circuit board briefly power up when I flip the power switch. Could this be some kind of diagnosis? Completely lost here.
Are you positive you got the connector on correctly? Many of these plugs will go on, even if they are shifted off to one side(leaving some pins not connected). I would take another look, and maybe disconnect first to look for any bent pins
  #22
Old 11-19-2013, 10:38 AM
Oggy Oggy is offline
Did you ever find out what those red lights mean? I have a similar problem. Mbox 3 Pro doesn't power up and one red light turns on and off after few seconds. I noticed that they "behave" differently if you use different power adapters.
  #23
Old 07-21-2014, 09:17 PM
Jilson Jilson is offline
regards
I have a problem with my mbox 3 pro
I upgraded to the latest driveres card for windows that are these
Fixed: Tuner & DSP Effects stop working after updating firmware (NOTE THAT if Tuner & DSP Effects are not restored, the unit May require a repair)
Mbox Pro Firmware Updates to v1.0.4
Windows 8.0, 8.1
but turning off my audio card does not catch me now, will not start.
not turn on the lights.
I read these messages on this forum and I have uncovered my card m box and all is well within it, in fact when I connect the power supply comprises a red light inside, which I saw when he had disarmed.
I need help to fix this please
  #24
Old 11-07-2014, 12:16 PM
lilcleo001 lilcleo001 is offline
Anyone get this working? I updated my drivers on my mac. After that, my interface never turned back on.
Tried different cables, installing older drivers, different port, and nothing. Interface doesn't turn on.
I did however notice that if I plug in the power cable while having the monitors on, I do hear a sound as if something working. But it just won't turn on.
Also, it does not show a firmware version after the update.
Any help/suggestions would be appreciated.
DIY I guess..No power on your new Mbox Pro 3? I fixed it!!! nstabl 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 02-07-2011 11:01 AM
DIY I guess..No power on your new Mbox Pro 3? I fixed it!!! nstabl 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 01-20-2011 02:39 PM
Re: Is the Power Harness Issue Fixed? blizzard 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 7 03-07-2007 07:57 AM
so... i guess i have a bad power harnass 16yearsjeff 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 02-25-2005 07:03 PM
new "mbox" not too far away, I guess Blutus 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 11-30-2004 04:34 AM
