Old 10-01-2010, 12:24 PM
AlexDC AlexDC is offline
Default Mic Pre Communication problem!
Hey guys, so i know this probably has a simple solution but...
Somebody ef'ed around with my mic pre and now every 5 seconds a protools dialogue appears on screen saying
"Protools is unable to communicate with PRE #1 on MIDI input port PRE, channel 1. Please power-cycle the unit and check your connections"
Power cycling doesn't do anything. and my connections are secure.
When i select "MIDI Chan" on the unit and set it one (this should fix it yea?) it doesn't do anything.
help me out here, i'm missing some ridiculous step some where. thanks!
-Alex
Old 10-01-2010, 12:25 PM
Default Re: Mic Pre Communication problem!
This is ON an HD system with 2 192's and A D-command as well.
-Alex
Old 10-01-2010, 01:26 PM
Craig F Craig F is offline
what is your MIDI interface?
I just dumped a POS M-audio MIDIsport for a MOTU Fastline
disable the PRE setting in Pro Tools
to go into MIDI Studio and check the MIDI interface
re-setup the PRE in Pro Tools
PT11 System Requirements link http://avid.force.com/pkb/articles/C...m-Requirements
Thank you,
Craig
Old 10-01-2010, 02:13 PM
Top Jimmy's Avatar
Along the lines of what Craig said, first delete and recreate the MIDI interface and routing in the AudioMIDI Setup. Applications>Utilities>AudioMidi Setup.
Second, trash Pro Tools prefs and databases. Follow the troublshooting links here. http://avid.custkb.com/avid/app/self...ommunity3=1078
In Pro Tools, re-declare the Pre in the peripherals setup dialog. If the Pre is assigned to channel 1, make sure you're routing to channel 1 here.
In the I/O setup, re-map the Pre to the apropriate inputs.
James Cadwallader
Hackintosh - Gigabyte Z77X-UP5TH, Intel Core i7-3770K, 32GB 1600Mhz DDR3, 2x SATA 6Gb/s 240GB SSD, 3x SATA 6Gb/s 1TB HDD, 1x Glyph 2TB USB3 HDD, Sierra 10.12.6.
Pro Tools HD 2018.12, Focusrite Red 8Pre, Mbox 3 (Mac)
Pro Tools 11.3.2, Mbox2 (Win 7)
003 rack communication problem... fab leseure 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 04-07-2010 03:52 PM
Communication problem with pre dubtoc ICON & C|24 13 11-18-2008 08:15 AM
Midi Communication Problem Davidblake 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 03-28-2006 08:19 PM
002 fader communication problem Seattle Guy 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 12 02-12-2004 06:10 AM
MIDI communication problem ringrose 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 04-14-2000 06:46 PM
