Old 04-19-2008, 12:20 PM
jonathans9 jonathans9 is offline
Default Play button flashes before starting
I have a new HD3 system. When I press the "play' button in the transport window the blue play button flashes a few times before playing. Is this normal. I am new to HD; with LE play was instantaneous.
JS
Old 04-19-2008, 12:31 PM
JSR JSR is offline
Default Re: Play button flashes before starting
sounds like you have midi count-off enabled.
Old 04-19-2008, 01:13 PM
Is midi count-off the conductor" If so, I do not think it is enabled>
Thanks, JS
Old 04-19-2008, 01:18 PM
sky88dd sky88dd is offline
Do you have pre roll turned on?
PPC G5 Dual 2.0, 8.5G Ram
PT 8 cs2 OSX 10.5.8
MBP Core 2 Duo 2.16, 2G Ram
PT 8 cs2 OSX 10.5.8
Mbox 2 Pro, Mini, Micro
Old 04-19-2008, 01:55 PM
Nope,
JS
Old 04-19-2008, 02:09 PM
Problem fixed. I did not have the midi functions enabled on the transport window.. And did not realize Mr Conductor and pre roll were enabled.
We are good now.
Thanks one and all.
JS
Music won't play. Play button flashes and Stop button lights up Mattitude 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 23 04-02-2018 09:02 AM
play flashes then stops. session wont play. hellbert Windows 21 03-31-2011 10:49 PM
Record 1 audio track, then go to record a second, the timer button flashes... help tdubthatsme General Discussion 5 02-27-2011 04:39 PM
Dead Talkback on PC - button now flashes when held audiomark ProControl, Control|24, Command|8 2 12-14-2007 01:17 PM
Mouse click changes play button but won't play screaminbytes 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 01-13-2007 10:13 PM
