Old 06-18-2019, 08:22 PM
Eric Lambert's Avatar
Default Increase in PT performance going from 32GB RAM to 64?
As the title suggests, I'm trying to decide if there will be an appreciable boost in performance/speed if I jump from 32GB to 64 using Mojave. I very rarely see a "running low on RAM" message, but I understand that the OS can operate more freely if there's an abundance of available RAM. What I don't know is if 32GB is generally considered enough freedom, or if I'd feel a boost going to 64GB. Enquiring minds want to know.
Old 06-18-2019, 08:34 PM
LizziF LizziF is offline
Default Re: Increase in PT performance going from 32GB RAM to 64?
I may be wrong (I actually am sometimes) but I think it depends on how many VI's and FXs you are using. PT runs fine on my 32 GB RAM computer and actually does okay on my 16 GB RAM laptop if Iimit the VIs and FXs.
I still bought a 64 GB RAM computer on sale recently because I'm starting to get into orchestration and that does need a lot more RAM to run.
Old 06-18-2019, 08:39 PM
If you already have your disk cache configured large enough to fully cache your sessions and are not seeing issues when running VIs and not getting other errors it is not likely to make any difference (except taking longer to POST ).
Extra memory won't really hurt... but what else can you spend that money on, I'd sure be looking at installing PCIe/NVMe boot/system drives on older Mac Pros for example (requires Mojave/recent Boot ROM image). I think you have a Mac Pro Cheesegrater right?
Extra memory can also help if you dont have DRAM DIMMs spread across the memory channels already. But again, if you are not seeing errors today, you likely wont' notice a real world difference.
Old 06-18-2019, 09:18 PM
ProTools has the necessary breathing room. I suppose what I was getting after was: if I increase RAM and the OS is entirely free to operate without constriction, would that in any way translate back into ProTools? Is there some type of slow-down -- of any sort, systemwide -- due to the fact that I have 32GB instead of 64?
I've been thinking through this and don't actually see an issue, nor do I predict or expect an increase, but I don't know all the ins and outs, hence the question.
I remember back a couple of decades when I first learned about swap files/disk caching and realized how much performance I was losing by having only 4MB RAM when I should have been using 8MB. My 133MHz Pentium 1 thanked me for that $400 upgrade.
So I'm generally just trying to take off any governors, wherever they may be. If I can spend a couple hundo and avoid a roadblock a few months down the road when I'm in the middle of a big project (because that's when these things happen), then I'm interested.
Old 06-18-2019, 09:49 PM
Unlikely to make any difference.... and modern OSes are a little complex to understand how their memory systems work.... like if you add more memory they may show they are using it... but often its never just getting rid of crap it does not don't need anymore.
Again if I did not have a PCIe/NVMe boot/system SSD I'd be working to get that. Or PCIe/NVMe SSDs for everything else.
Old 06-18-2019, 09:59 PM
arche3's Avatar
arche3 arche3 is offline
I didn't think pcie nvme ssd would work in the 5:1 cheese grater. I have to research this.
Sent from my SM-G975U using Tapatalk
Old 06-18-2019, 10:06 PM
Yes it will work or I would not have mentioned it. NVMe boot support requires Mojave and the Mojave included Boot ROM upgrade. No other hacks required anymore to get that to work.
Old 06-18-2019, 10:25 PM
arche3's Avatar
This is madness. My 5:1 keeps going and going.
Old 06-18-2019, 10:28 PM
Well Apple has tried to rain on that parade by saying no support for macOS Catalina. But who knows what might happen, or what people can hack to get running.
Old 06-19-2019, 12:05 AM
umm.. high sierra?
Performance hit in 8.0...or increase? Shan 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 46 01-02-2009 03:07 PM
Does lot's of RAM really increase performance? bassmac 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 09-03-2002 01:18 PM
