Old 07-12-2003, 09:13 PM
adamjames adamjames is offline
Default More plug-in problems...
I can't seem to get PT LE to find my new plug-ins. When I installed it, the install software asked which hard-drive to put it into. I put loaded onto my main hard-drive where my PT software is located. I then moved it to the plug-in folder in Digidesign located in the library section of my hard drive.
The plug-in is an Antares pitch correcting software and there were three options for install, i.e. RTAS, MAS etc. I loaded all of them because I didn't know which one to install.
I still can't find it when I open PT. My question is which section of the plug-in folder does PT read from? Should I have the entire Antares folder in there or should I pull out the specific icon and drop it into the plug-in folder?
I hope this makes sense. Any help would be appreciated.
adam
PT LE 6.4cs9
Digi 002
Dual Mac G4
OS X Panther
Old 07-13-2003, 05:26 PM
TAPKAE TAPKAE is offline
Default Re: More plug-in problems...
I think its in the system folder and within that, its in the DAE folder. Dig around in there. There is a PI folder.
OS 10.3.9
1.25 mhz single G4, 1.25GB RAM, Firewire & Internal recording drives, Nomad Factory plugins
PT 6.4, 001, Motormix
Old 07-13-2003, 10:45 PM
El CaCa El CaCa is offline
Actually in OSX the plug in folder is in
HARD DRIVE>LIBRARY>APPLICATION SUPPORT>DIGIDESIGN>PLUG INS
Try putting your plugs in there and it should work...
el Caca
I am the Chupacabra!
Old 07-13-2003, 10:53 PM
That's exactly what I did but in the PI folder, there's a couple different parts. I'm not sure whether I should put the entire Antares folder in there or pull out certain sections.
PT LE 6.4cs9
Digi 002
Dual Mac G4
OS X Panther
Plug-In Problems Awesomealex9 macOS 8 05-11-2012 07:16 PM
plug-in problems stooly 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 07-12-2008 04:11 PM
ProTools 7 Plug-in Problems? Re:Which 2 Plug-ins. Chris DPA 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 8 12-30-2005 12:47 AM
I have some problems with my MDW Eq plug-in ... Julien Apruzzese Pro Tools TDM Systems (Mac) 7 11-18-2005 07:29 AM
Plug in problems Gkyaun 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 01-22-2004 11:28 PM
