Old 09-21-2019, 01:07 PM
Ellis Beckwith Ellis Beckwith is offline
Default Slate Trigger 2 Flamming
I've searched here and on Google, but came up empty. I just purchased and installed Trigger 2 Platinum. No problems with the install. But, when I used it on a drum track every hit is doubled, like a flam. this is true even when the mix is set at 100%. I've adjusted every parameter, including retrigger, sensitivity, detail, and the gate. This occurs on both audio tracks and midi tracks. I've quit PT and restarted, but nothing changed. After work today I will restart the Mac and then reinstall Trigger 2 if necessary.
Has anyone experienced this with Trigger 2, and if so, how did you solve it?
Thanks
Ellis Beckwith
iMac (mid 2011), Intel Core i5 2.5 GHz, 32GB; Samsung 500Gb SSD;M-Audio Oxygen 25, Faderport 1
Old 09-21-2019, 02:16 PM
AlexLakis AlexLakis is offline
Default Re: Slate Trigger 2 Flamming
Do you have delay compensation enabled? I believe Trigger 2 adds 1024 samples of delay, you'll have to compensate for it somehow.
Old 09-21-2019, 02:30 PM
Yes, I do.
Ellis Beckwith
Old 09-23-2019, 04:05 PM
WernerF WernerF is offline
When I have this problem, which occurs every now and then, I simply de-activate and then re-activate the track that Trigger 2 is on. If that doesn't work I restart Pro Tools.
Old 09-23-2019, 04:52 PM
restarting PT seems to have solved the problem.
Ellis Beckwith
Old 09-23-2019, 05:12 PM
Great!!
HTML code is On
S6 and Slate Trigger. del cosmos Pro Tools | S6 5 01-23-2018 08:16 AM
WTB: Slate Digital TRIGGER 2 EuroMix Buy & Sell 0 06-07-2015 07:49 AM
FYI - Slate Trigger EX jmitchell1532 Pro Tools 10 0 12-10-2012 08:55 AM
Slate Trigger Outputs Siegfried Meier Pro Tools TDM Systems (Mac) 9 11-27-2011 11:05 AM
Trigger - flamming on Midi input fman Pro Tools TDM Systems (Mac) 0 05-25-2010 12:32 AM
