Old 09-06-2010, 08:04 PM
PostHuman PostHuman is offline
Default Why does Pro Tools only auto create 1 MIDI channel for a VI?
Why does Pro Tools only auto create 1 MIDI channel for a VI? How do I select another MIDI channel for a VI? No other MIDI channels show up...
http://img28.imageshack.us/f/54116742.png/
MacPro 2x3GHz Quad-Core Intel Xeon, SL 10.7.2, PT HD 10, Avid HD I/O & PRE, M-Audio Axiom Pro 49, MOTU MIDi Express 128, & many synths.
Old 09-06-2010, 10:14 PM
Top Jimmy's Avatar
Default Re: Why does Pro Tools only auto create 1 MIDI channel for a VI?
You're looking in the wrong place. That is the output side of the "Instrument" input. Naturally, it will route to the default input (#1) of the instrument inserted on that track. If you want to route MIDI data to an alternate MIDI input of that instrument, you do it from the output of the MIDI track that the data is on. In the picture you linked, move down to the I/O routings on the MIDI 1 track and select the destination in the output that currently says "none".
James Cadwallader
Hackintosh - Gigabyte Z77X-UP5TH, Intel Core i7-3770K, 32GB 1600Mhz DDR3, 2x SATA 6Gb/s 240GB SSD, 3x SATA 6Gb/s 1TB HDD, 1x Glyph 2TB USB3 HDD, Sierra 10.12.6.
Pro Tools HD 2018.12, Focusrite Red 8Pre, Mbox 3 (Mac)
Pro Tools 11.3.2, Mbox2 (Win 7)
Old 09-07-2010, 08:21 AM
Thank you for your quick reply. I get the same thing look.
http://img835.imageshack.us/img835/4599/71355069.jpg
Old 09-07-2010, 11:04 AM
Top Jimmy's Avatar
Ah, OK. That means that the Arturia CS-80V2 only supports one MIDI path per instance. That makes sense since it is a synth (single instrument) and plugins like Structure or Xpand2 are actually samplers that each can host multiple instruments.
If you want more CS-80V2 parts, just create another instrument track and and put another CS-80V2 on it.
James Cadwallader
Old 09-08-2010, 05:31 PM
Your right! Thank you, I thought I was going crazy...
Auto-create multiple playlists Stig Eliassen Pro Tools 10 0 08-31-2012 08:01 AM
Auto create sub paths bug??? Shonk Studios Pro Tools 9 0 09-13-2011 03:19 PM
Auto create regions blackbirdstudio Pro Tools TDM Systems (Mac) 6 02-12-2010 08:17 PM
Auto Create new Playlists from 7.x into PT 8 clusterer Pro Tools TDM Systems (Mac) 0 06-08-2009 08:19 AM
auto selecting the proper midi channel Jepse MIDI 0 04-09-2004 11:08 AM
