Old 09-21-2019, 04:40 PM
d.hill7 d.hill7 is offline
Default No inputs in PT with Eleven Rack
Im a little out of touch as I haven't used PT in 5 or 6 years.
I recently picked up Eleven rack and updated my protools. My outputs are fine, but when I arm a track with any input (guitar, mic, line, rack) I can not for the life of me get a signal. All the inputs seem correct in correlation with the audio midi setup and all inputs work in garage band. When Eleven is on, all track appear in I/O as ready and available, but I just can't seem to get a signal. I am using the rack editor and can hear a guitar or mic through this.
Old 09-21-2019, 04:56 PM
Default Re: No inputs in PT with Eleven Rack
Hi welcome to DUC
[edited to fix typos/clarity]
What do you mean the "outputs are fine"? Do you mean the Eleven Rack playing back guitar or do you mean able to play prerecorded audio from within Pro Tools? Can you open a session, create a new stereo audio track, drag and drop a know good MP3 or similar file on that track. Click play. Does that play out the main outputs of the Eleven Rack OK?
What are you trying to record? Mic? Guitar? What guitar and pickups (esp. want to know if they are powered high-gain pickups)? What mic?
Do you know how to use an Eleven Rack standalone? Can you get a guitar to output through the rig while using it standalone? If you are new to that get the Eleven Rack fully working stand alone before trying to use Pro Tools, especially pay attention to that the rig input is setup to Guitar In.
How are you determining you do not have a signal? Not hearing anything? Not seeing meters move? Both? If you are trying to record the dry guitar signal/guitar input it will be very low level with most electric guitars, you have to zoom in to see it or insert an amp plugin inside Pro Tools. If you already know how to use the Eleven Rack stand alone start by recording the wet rig-outputs to a stereo audio track.
What computer and OS version are you running? What version of the Eleven Rack driver did you install.
After starting up Pro Tools hold down the 'N' key and keep it held down until the playback engine dialog box appears and then make sure the Eleven Rack is selected.
Make sure you are recording to an audio, not an instrument track (it has to be an audio track, a very common mistake)
Old 09-23-2019, 09:40 PM
All my previous sessions run fine. when I drop recorded audio down into the new track (the one I intend to record off of) playback is fine. No troubles with output.
No input will work off of eleven (guitar, mic, line, dry). the mic sm7 and p90 pickups. I can only hear playback through 11 and editor, but I get no signal to selected channel. I assume it works plugged into a cab but have yet to try. As I said, I get a signal in GarageBand, so it must be a signal path through to PT.
Old 09-23-2019, 10:01 PM
Are you on Mojave? My guess...
System Preferences > Security & Privacy > Privacy > Microphone. You need to check Pro Tools "microphone" access... meaning allow any inputs into Pro Tools.
Widely discussed on DUC in the past.
Are you running Pro Tools 12 on Mojave? Not a good idea.
Please update the info in your profile and/or next time you post here include all the correct version info in your post.
Eleven Rack/Can't see the Inputs capecin Eleven Rack 5 04-26-2013 07:59 PM
Eleven Rack window responds to changes on Eleven Rack, unable to record. pine Eleven Rack 6 08-02-2012 07:50 PM
Eleven Rack No Inputs in Reaper Imran5000 Eleven Rack 10 07-10-2012 05:59 AM
Eleven Rack and Eleven Rack control window not matching 11R Newbie Eleven Rack 3 04-18-2012 06:07 PM
Using Eleven Rack inputs like POD X3 inputs dayslypper Eleven Rack 1 10-09-2010 09:15 PM
