Old 04-10-2018, 09:32 AM
jamburg jamburg is offline
Default I'm thinking about moving from PT, convince me otherwise !
Hello !
I've been using Digidesign/Avid products professionally for 20+ years starting with an AudioMedia Card, to a Mix+ System to my current HDX with 32channels i.o.
I own and operate a multi-room facility of which I rent 2 other rooms out to other producers/composers. I had previously run the place as a purely commercial studio but in the past 4 years or so I've transitioned to make my income mostly through scoring, song-writing and production with the odd session here and there. Currently running PT 12.4 with a perpetual license and I'm happy with my workflow in ProTools. I usually can get away with running VI's natively and I've got a Vienna Ensemble Server running for larger orchestral templates when needed.
Here's the larger story.. In the next year or so I plan on closing this space (which I own and can rent out to a more profitable enterprise like a laundromat :) and move into another. The new space (yet to be found) is a complete unknown. All I know is that I will be continuing to work scoring and producing.
I've long ago let my support plan lapse and have been loosely following developments with PT from afar. I won't go into much detail but from what I can understand so far, I'm not exactly pleased with the direction Avid has been taking.. for instance having to buy a DigiLink license to continue to use my converters ( i hope that I'm misunderstanding this )
Though I love ProTools and will obviously need to have a copy on hand, if I'm not running a purely commercial space I'm not sure I need to stay on board. I could easily work on Logic, Cubase even Reaper these days.
Curious if others on here are having similar thoughts ? Please discuss !
-j
Old 04-10-2018, 07:31 PM
Default Re: I'm thinking about moving from PT, convince me otherwise !
This will be a can of worms, but being the opinionated SOB that I am, I'll weigh in. If you only work alone, try everything and see what works best for you. You can keep using your current hardware and keep 12.4 HD for opening old PT sessions or converting if you get sent PT sessions. There's no requirement for you to move to newer PT versions(hey, the guy next door to me is still running version 8) and the Digilink license is not required until you move to 12.6(IIRC) and if you decided to move up, its a one-time purchase of $299(not that bad if you make your living with this stuff).
As for other software,(again, my 2 cents) Pro Tools handles audio editing better than the rest(opinion), but you may find Cubase or Logic much better for heavy midi use(although, 2018 is getting a serious push on the midi side). Sometimes you need to give the other options a good test to make you feel better about PT In any case, good luck on your next venture!
Old 04-10-2018, 08:08 PM
BScout BScout is offline
If you previously had a working HDX system (and it seems you did with 12.4 and HD software), you are grandfathered in and will be given a free Digilink license.
If you do a reinstatement and it isn't auto-included with the upgrade (but it should be part of a perpetual bundle for upgrades which would include a bundle license of: 10 HD,11 HD,12 HD, 2018HD , Digilink licenses), then contact support and they'll send you the license. This is different for new HD users who won't get a bundle but only the latest. And if you didn't have the hardware prior to a certain date, then the Digilink license would need to be bought too. But if you had 12.4, you were before that cut off date.
As for jumping ship, I fully believe in seeing the other side of the fence. I still see Pro Tools MIDI as being 5 steps (or more) behind the big guys (Logic and Cubendo) but for mixing/routing, I think Pro Tools is still the best.
If you are moving more to scoring, you might prefer the MIDI features in the others. I wouldn't sell your Pro Tools gear though even if you freeze where you are at -- you still need compatibility with the Film/TV world if you intend to really "make it". Here, I'm talking actually scoring to picture (vs doing library tracks) where you'll work with edit rooms and music editors.
Pro Tools Ult 2019.6, HDX 3, MTRX/SPQ, HD OmniMac Pro 5,1 - 3.06 GHz 12 core - macOS 10.13.6RAM 64GB, SSD 4 x 2TB, GPU GTX 980 4GB
Old 04-11-2018, 04:57 AM
musicman691 musicman691 is online now
I
Two of the biggies for scoring & producing seem to be Cubase and Digital Performer. DP has a 30 day fully functioning trial and runs on both Windows and OSX. One version that does it all. One of the major dings against DP is on a lot of monitor screens the fonts are small with no way to change them inside the program. That and the gui is cluttered.
Old 04-11-2018, 06:57 AM
KV626's Avatar
KV626 KV626 is offline
Depending on your MIDI needs, you might find something more interesting and/or effective in the competition. On the audio side, considering you've been using PT for 20+ years, nothing comes close.
As for me, I do everything on PT, I don't really see its so-called MIDI limitations, it just works for me. I've been using it for well over 15+ years, so PT is where I feel the most "at home". I know it left and right, so there's no way I can be as fast on another DAW. With PT I can concentrate on making music, with another DAW I have to concentrate on how to make music, and I don't like that. PT's workflow is the most streamlined imo. Others would probably disagree...
Mac Pro 5,1 (Mid-2012) 12-core 2 x 3.3 GHz / MSI RX 560 / 40GB ram / macOS 10.14.5 / Pro Tools 2019.5 / Logic Pro X 10.4.4
Arturia Keylab 88 Presonus Faderport 8 MOTU 896 iPad Air 2 w/ PT Control
NI Komplete Ultimate 11 • Albion One • Soundiron Choirs • Pianoteq • Analog Lab • VSL SE/Chamber Strings • etc
Old 04-11-2018, 11:16 AM
Personal anecdote on the MIDI deal:
Used Sonar for a number of years and when I needed a new computer I went to PT and a Mac. Spent years with PT and keep reading about PT's supposed MIDI shortcomings so decided when Avid changed from lifetime updates for a whole number version to keeping up one's Avid tax I started working in DP (still keeping PT going). After about a year of trying to work efficiently (note that word) in DP I tired of the workarounds and went back to PT full time except for the few pieces I have going in DP.
The moral of this story - try others but if you're comfortable with a certain program don't give up on it as you may well find the grass is NOT greener on the other side.
Old 04-11-2018, 11:30 AM
Cowboy Bob's Avatar
Cowboy Bob Cowboy Bob is offline
Originally Posted by musicman691 View Post
....you may well find the grass is NOT greener on the other side....
Agreed, Jack.
I usually find that if the grass is greener somewhere else, it is because of all the manure being spread.
But that's just the opinion of an ol' country boy.
Squaw Creek Road Studio
Bob
Pro Tools Standard (current version)| Avid Eleven Rack ERXP | Sibelius Ultimate (current version)
3.6GHz 8-core 9th-generation Intel Core i9 processor iMac w/40GB RAM | 1TB SSD | macOS Mojave |
Focusrite Clarett 8Pre X | Lenovo i7 ThinkPad | Win 7 Professional | Avid 003 + Rack |
Old 04-11-2018, 11:44 AM
Originally Posted by Cowboy Bob View Post
Agreed, Jack.
Well said(or is that "well spread")
Old 04-11-2018, 12:27 PM
Bob Olhsson's Avatar
Bob Olhsson Bob Olhsson is offline
Video is moving so fast that I wouldn't even think about using anything but an up to date version of Pro Tools. Video technology today is like audio was back in the '90s. You may not need HDX but you will need PT's video, surround and VR capabilities.
Bob's room 615 562-4346
Georgetown Masters 615 254-3233
Interview
Artists are the gatekeepers of truth! - Paul Robeson
Old 04-15-2018, 06:58 AM
K Roche's Avatar
K Roche K Roche is offline
Agreed, Jack.
Sometimes from the mouth of cowboys is like from the mouth of babes . And the simple profundity is easy to miss
I am going to remember that little pearl of wisdom
System :
Avid HD Omni I/O Interface ...Mid 2010 Mac Pro/ processor- 3.33 6-core Intel Xeon "Westmere" w/ Memory- 24 GB, Radeon Pulse RX 580 8GB GDDR5 Dual HDMI Graphics Card..... OS- Mojave 10.14.6, and PTHDN 2019.6 on on primary boot drive (SSD PCIe 512 GB Samsung SM951) FCPX files storage on Samsung 970 EVO 1TB and PT sessions storage on 2nd Samsung 970 EVO 1 TB -- both in dual drive Crest I/O PCIE controller adaptor card
"Peace cannot be kept by force. It can only be achieved by understanding" Albert Einstein
Enjoy the Journey
.... Kev...
I am over Apple thinking of moving back to windows advise needed. Trainwreckmusic Windows 8 05-19-2016 02:31 PM
Thinking of moving to Pro Tools. I have Questions.. TheEdster75 Windows 5 04-17-2012 10:06 PM
Thinking of moving to iMac, help please! paulrgmusic macOS 19 08-17-2011 03:44 AM
Windows Thinking of moving over to Mac Pro Loyd981 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 03-03-2010 01:30 PM
Thinking of moving from Xp to Vista Flpalla Pro Tools M-Powered (Win) 1 10-11-2008 11:23 AM
