Old 10-07-2009, 09:26 PM
johanchurchill johanchurchill is offline
Unhappy Protools / MOTU 1296 campatability?
Greetings,
I am working at a friends studio tomorrow and wanted to know if the Protools LE 7.4 (Mac) system he has can interface with a MOTU 1296? is it possible to use the MOTU as an interface instead of the mbox?
I dont need to do any editing if that makes a difference, I just need multi channel outs so I can proccess each track seporately using external gear.
thanks so much!
-johan
Old 10-08-2009, 12:05 AM
lincol1 lincol1 is offline
Default Re: Protools / MOTU 1296 campatability?
only digidesign hardware will work with pt
Lincoln Mitchell
www.studiofifty.net
Mac Pro 2.66 Ghz Quad, 10.6.6, 12GB Ram, PT9, Logic 9, Kontakt, East West, VSL, Waves, Sound Toys, IK Multimedia
RME FF UC, Focusrite Octopre mkii, UA LA 610 mkii, MC Transport, Yamaha HS80M, Lauten, AKG, Sure, Blue
Old 10-08-2009, 09:18 AM
OK, is it possible to use the MOTU 1296 in ADDITION to the Mbox interface?
Old 10-08-2009, 09:26 AM
getz76 getz76 is offline
No.
| Logic Pro 9 | Reason 6.5 | Pro Tools 10 | MOTU UltraLite mk3 | RME ADI-2 | Summit Audio 2BA-221 x 2 | MOTU 8pre x 2 |
| Mac Pro (4,1) 2.26gHz Xeon x 2 16gB OS X 10.7.4 | Macbook Pro (8,2) 2.2gHz i7 Quad 16gB OS X 10.7.4 |
Old 10-08-2009, 12:26 PM
Dism Dism is offline
Pro Tools works exclusively with it's own hardware. It is the ultimate pirate protection. You're only option for some variety is Pro Tools M-Powered which only works with M-Audio gear.
Otherwise, you're only other option for more ins/outs with extra hardware in LE, is via ADAT through an 002 or 003.
D
a n t h e I n c r e d i b l e S o u n d M a n
"Svetlana" v1 - 4.2GHz i7, 16GB RAM, OSX 10.7.4
Liquid Saffire 56 - PT10.2 - BFD2, VCC, Duende Native, Play 3.0
_C U R R E N T-D V E R B-S C O R E:515
Old 10-08-2009, 01:25 PM
DanielWiklander DanielWiklander is offline
OK, so no option of using, say, an MBox 2 as an enormous dongle and utilize the S/P DIF I/O:s? Just a thing I heard earlier today would be possible, never tried it.
MacBook Pro 15,4" 2,5 GHZ, 4 GB RAM, OSX 10.6.8, Pro Tools 10, Digi003
Old 10-08-2009, 01:56 PM
SPDIF works fine. Two channels only. On an Mbox 2, you can effectively run 4 channels simultaneously.
On the 002/003 series, you have ADAT in for 24-bit/48kHz x 8 channels.
Old 10-08-2009, 05:58 PM
Any I/O (preamps, A/D or DA, etc) that runs through the Digidesign interface will work. It is when you try to use a different interface (alone or along side of it) that it does not work with Protools LE. Here is a breakdown of the I/O for each interface for Protools LE:
The Mbox 2 Micro has no input nor Mic Pres but 2 channels of output (2 Analog)
The Mbox 2 Mini supports up to 2 channels of input with one Mic Pre (2 Analog)/2 channels of output (2 Analog).
The Mbox 2 supports up to 4 channels of input with 2 Mic Pres (2 Analog and 2 digital SPDIF) and 4 channels of output (2 Analog and 2 digital SPDIF)
The Mbox 2 Pro supports up to 6 channels of input with 2 Mic Pres (4 Analog and 2 digital SPDIF)/4 channels of output (2 Analog and 2 digital SPDIF).
The Digi 002/002R/003/003R supports up to 18 Channels of input with 4 Mic Pres (8 Analog, 8 ADAT Optical, 2 digital SPDIF)/18 channels of output (8 Analog, 8 ADAT Optical, 2 digital SPDIF)
The Digi 003R+ supports up to 18 Channels of input with 8 Mic Pres (8 Analog, 8 ADAT Optical, 2 digital SPDIF)/18 channels of output (8 Analog, 8 ADAT Optical, 2 digital SPDIF)
I hope that helps.
Obsidian Dragon
Mac Studio M1Max - 64GB
Help with Motu MTP and Protools LE 6.9.2 pernati666 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 07-23-2007 04:23 AM
Campatability question - PT 6.7 and 5.1(?) Eric Klinger 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 03-25-2005 12:09 AM
Motu 1296 as good as HD 192 narleysoundz Pro Tools TDM Systems (Mac) 28 03-18-2002 09:41 AM
Can you use ProTools LE or ProTools free with MOTU 828 ? Mr Scary P4P 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 02-16-2002 11:18 PM
Pro Tools VS MOTU 1296 kidfrenzy General Discussion 4 05-03-2001 08:25 PM
