Old 05-15-2010, 02:51 PM
cbwhitebu cbwhitebu is offline
Default Hiss on all tracks after import
I am running Protools LE 7.3 on an HP DV5327 laptop using an MBox Mini2. I am using an external OWC firewire drive.
I had some 2" 16-track tapes converted to ProTools sessions (version 6) and am trying to import the audio. The import appears to work fine (import succeeds without error, waveforms are displayed correctly etc) but the meters are pegged during playback and all I hear is some serious white noise.
I have seen others reporting this problem on the internet (couldn't find anything on this forum) but I have not seen any solutions.
Any help would be sincerely appreciated.
Chris
Old 05-15-2010, 06:01 PM
tlennon tlennon is offline
Default Re: Hiss on all tracks after import
Can you playback any other wav files that have not been converted without the noise? Can you post one of the wave files?
Terrence Lennon
Ivory Key Productions
Old 05-15-2010, 07:58 PM
Turns out that everything works fine if the project is copied off the external hard drive to a local drive....weird...looks like any audio file on the external drive just creates white noise when played back through ProTools.
Sigh...yet another mystery to be solved.
PT10: Import tracks with overlay+match tracks not working Frank Kruse Post - Surround - Video 3 12-02-2011 09:06 AM
003 and Eleven Rack - Digital hiss when rec arming SPDF tracks kkguitar macOS 1 10-11-2011 09:42 PM
import audio from CD creates hiss,double, noise violetsun 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 11-28-2006 04:02 PM
Instrument Tracks Produce Hiss vseus 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 6 11-15-2006 03:42 PM
Need plug-in to reduce hiss on tracks - advice too gbross 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 02-21-2005 09:12 PM
