Old 11-29-2016, 08:55 AM
The-Edge The-Edge is offline
Default Eleven Rack and Behringer FCB1010
Hoping someone may know the answer to this I ordered the Behringer FCB1010 to work with my Eleven Rack its on its way I wasn't sure what cables come with it or what type of cable I may need to hook it up.. Any assistance would be greatly appreciated.
Old 11-29-2016, 10:13 AM
JoelG's Avatar
JoelG JoelG is offline
Default Re: Eleven Rack and Behringer FCB1010
You'll need a midi cable like this: http://www.sweetwater.com/store/detail/MIDI10 keep in mind that the length of the cable determines how far away you can have your pedal board from the Eleven Rack. I think I bought a 15'.
I'd also recommend looking into EurekaPROM: http://www.eurekasound.com/eurekaprom
Joel
Jam Space:
HP Elite 6300 / Core i5 3770 / 24GB RAM / Win 11 Pro
Pro Tools HD / Focusrite 18i20 + M-Audio ProFire 2626
Home:
Asus B450 Pro4 / Ryzen 5 2600 / 32GB RAM / Win 11 Pro
Rig:
Eleven Rack / ART SLA1 / Two 2x10 Passive Monitors / FCB1010 w/ EurekaPROM
Old 11-29-2016, 10:18 AM
Joel,
Thanks, yes I forgot to mention I ordered the EurekaProm after doing some research. I just never saw any details on connecting to the 11R. Thanks for the help !
Old 11-29-2016, 12:21 PM
JoelG's Avatar
Cool, overall I'm quite happy with it. The expression pedals aren't overly robust, so I don't know how much gigging it would handle, I'm quite gentle with my gear.. :)
Also, the new EurekaPROM is supposed to switch patches quicker, whereas the version I have there is a slight delay.
Joel
Jam Space:
Home:
Rig:
Old 11-29-2016, 12:43 PM
OK Thanks for the info, This is for my home studio, just getting back into the music scene so no gigs in the near future but will never rule it out :)
Old 07-07-2017, 11:59 AM
calv calv is offline
I use the FCB1010 without ordering a eureka or uno prom etc. Just follow the steps on the behringer website about how to program it to switch presets. The 11rack has letters and numbers in the preset names which confuses things so I kind of did things in reverse.
What I mean is, program pedal 1 to activate (for example) patch 20. set pedal 2 to patch 21 etc. make sure the midi out of the fcb1010 goes to the midi in on the 11 rack and vice versa with the other lead. At this point we don't know what patch '20' is going to mean on the 11 rack until we hit the pedal and we see which patch on the 11r gets chosen.
Now, test it to see that it is switching patches. (both units must have the same midi channel though (I used ch 1).
now go to the 11 rack and choose the patch that you want for pedal 1 and save a copy of it it (on the 11 rack) in the same patch location as what is already linked to the fcb1010. So if pedal 1 chooses 'a3' on the 11r for example then you save it there. In my case, I found a nice clean patch and saved it to pedal 1.
I then wanted a dirty rhythm sound for pedal 2 so i pressed pedal 2, noted which patch got called (let's pretend it's 'a4'). Now look for a suitable patch on the 11R and save a copy by hitting 'save' then turn the 'scroll' wheel to 'a4' and hit 'save' again.
Then I wanted a solo channel for pedal 3 which was similar to the rhytm sound but with delay so I saved the same patch but then added delay and resaved it. I did the same for pedal 4 but added a 'wah'. This meant that I didn't have to carry out complex programming to turn 'delay' or 'wah' on and off, I just use separate patches that do or don't house them.
I know the more efficient way is to just type in the correct patch number but I wasn't aware how to do it and didn't want to waste time trying to work out a formula.
You'll also need to calibrate the wah by following the advice on the behringer site to choose the wah and set (in my choice) the up positio to 1 and the down to 127 ( for min to max) and to link it to the 'wah' on the 11R use the number '4' as the 11R manual tells you. I hope that helps someone!
Old 09-12-2017, 09:59 AM
Thanks Calv..
Behringer FCB1010 with Eleven Rack Kruegmeister Eleven Rack 11 12-13-2015 08:31 PM
fcb1010 w/eleven rack Rob487 Eleven Rack 27 09-09-2012 03:53 PM
11Prom - FCB1010 - Eleven Rack - DEMO Benoni Eleven Rack 39 09-24-2011 08:40 PM
Behringer FCB1010 Uno Eprom Sysex File For The Eleven Rack Benoni Eleven Rack 3 06-04-2011 06:17 PM
How do I use Eleven Rack with FCB1010!?! zenabi916 Eleven Rack 6 11-22-2010 01:31 PM
