  #21
Old 08-02-2017, 01:10 PM
Rectifried Rectifried is offline
Default Re: Random CPU Spikes (-9173 errors)
Same s##$%$ here almost Nothing in the session.
ALL optimationsDONE
CPU at 8%
512 buffer
Complete BS
Ived crawled through every thing to fix this, its really this bad ..
And YES some will say ITS your computer etc..on every version of this thread
But why is this Thread going ON and ON
if its NOt an issue with this "professional" software
Im not even asking for features I just need to HIT PLAY and WORK
So many DAWs arent THIS BAD
dealling with this for 18 years.. and still wtf
Hal Cragin On the DUC Since The Year 2000 AD
Ventura ,PT 2022.10, MacbookPro 13"[2020] M1 16G, Antelope Orion 32+ Gen3..SSL Sigma summing, SMART Comp C1LA, CharterOak EQP-1 Oceanway Audio HR4S monitors . SSL X-Rack w XR618 compressors, dbx 160x [2]
  #22
Old 08-02-2017, 01:58 PM
The thread is going on and on because nobody has provided complete and proper details of their setups Look up top for the link called Help Us Help You, have a read and then post the proper information so folks here can try to help
  #23
Old 08-02-2017, 03:08 PM
john1192 john1192 is offline
ALL optimationsDONE
CPU at 8%
512 buffer
Complete BS
hi, i just looked up your Computer Specs .. 2012 4 or 8 GB of Ram .. do i have this correct ??? happy to try and help you get your Rig Working !!!
http://www.everymac.com/ultimate-mac...=MacBookPro9,1
Macmini M1 8/512 -OS 12.3.1 and PT2022.4
Logic Pro X 10.7.4
RME BabyFace Pro
Macbook Pro july 2014 2.5ghz 16gb ram 512gb SSD - OS11.6.5 - PT 2021.3
Logic Pro X 10.7.4
RME BabyFace Pro
  #24
Old 08-06-2017, 09:08 PM
whatsinausername whatsinausername is offline
Default Re: AAE error -9173 stronger than ever on PT 12.5
Has anyone found a resolution to this issue?
I'm running PT 12.7 HD on a 2.7GHz 12-core Intel Xeon E5 processor with 64 Gigs of RAM, 1TB SSD with a Thunderbolt + 16 x 16 Analog setup. I am unable to play even a SINGLE track with NO plugins. AAE 9173 error every time.
Having just spent more than $10K on this setup, I'm naturally quite upset. I've tried a clean re-install, deleting the click plugin, swapping computers, downgrading to 12.6, etc. No luck. CPU spike/9173 playing a single track.
At this point, I'm assuming Pro Tools is dead, and I should switch to Logic, or some other competitor. Makes me sad, as I've been a loyal customer for more than a decade.
I'll be contacting Avid and asking for a full refund for the Thunderbolt + 16x16 system. I must say, having read through this entire forum, this looks like a class action consumer protection suit waiting to happen.
  #25
Old 08-06-2017, 09:12 PM
Default Re: Yet another external display thread
I'm very interested in any resolution here as well.
I'm running PT 12.7 HD on a brand new MAXED OUT Mac Pro with an external thunderbolt display + Thunderbolt/16 x 16 Analog setup. I am unable to play even a SINGLE track with NO plugins. AAE 9173 error every time.
  #26
Old 08-06-2017, 09:17 PM
Cross-posting from another thread in an effort to resolve this issue.
I'm running PT 12.7 on a 2.7GHz 12-core Intel Xeon E5 processor with 64 Gigs of RAM, 1TB SSD with a Thunderbolt + 16 x 16 Analog setup. I am unable to play even a SINGLE track with NO plugins. AAE 9173 error every time.
At this point, I'm assuming this is a fatal flaw that does not relate to my hardware setup, and I should switch to Logic, or some other competitor. Makes me sad, as I've been a loyal customer for more than a decade.
  #27
Old 08-06-2017, 09:30 PM
Default Re: Dear Avid
I've used PT7 successfully for years with an old 002 rack. I Finally decided to pull the trigger on an HD rig, and spent $10K on a PT 12.7 HD Thunderbolt + 16 x 16 Analog setup and a brand new Mac Pro.
Out of the box, no plug-ins or aftermarket anything, Pro Tools is unable to play a single track with no plug-ins, effects, or VIs. I get a 9173 error every time. I've been troubleshooting for weeks with no resolution in sight.
I appreciate the frustration in this thread. I don't throw around hyperbole; I feel defrauded in every sense of the word by this company.
  #28
Old 08-06-2017, 10:06 PM
YYR123's Avatar
YYR123 YYR123 is offline
Default AAE error -9173 stronger than ever on PT 12.5
Sounds like a weird problem
You should go get another computer and try it, b/c I run PT12.5.1 on a E5 8 Core Xeon and don't have that issue.
Daniel
  #29
Old 08-06-2017, 11:18 PM
propower propower is offline
If you have a second somewhat recent Mac (any will do) please try installing PT and iLok driver on that and see if this makes things better. If the 9173 is that rampant - there may be a hardware issue with your new MP. Replace all the cables too. I have run many systems and although 9173 is there off and on it was never - every time. If this stuff was new from a dealer or AVID - you should be able to get direct support and if that doesn't work - either get replacements or return it.
2017 27" iMac 3.8GHz i5, 1TB SSD
Logic ProX, Studio One V4, PT current version, Apogee Ensemble TB
Musician: http://www.ivanlee.net/
Design Engineer: http://www.propowerinc.com/resume.html
  #30
Old 08-07-2017, 07:36 AM
YYR123's Avatar
Yes and when you get another system
Trouble shoot with just PT Installed
Many 3rd party plugs can cause errors
Daniel
AAE 9173 Pro Tools ran out of CPU power Kinh Pro Tools 11 223 12-10-2017 09:39 AM
Pro tools running out of CPU power AAE-9173 ccapretta macOS 4 12-07-2015 07:27 AM
CPU Power issues AAE -9173 errors Cryos Pro Tools 11 3 11-01-2015 03:39 AM
Pro Tools ran out of CPU power. AAE -9173 graj Pro Tools 12 13 10-27-2015 12:34 PM
Pro Tools ran out of CPU power - Error Code AAE-9173 dewmi Pro Tools 12 1 10-24-2015 10:58 PM
