Old 07-07-2012, 09:38 AM
tomhartman tomhartman is offline
Default Share Your Favorite Transport Setups..
As a new user of Transport and Mix, I've set up some things I use often as shortcuts, but got to wondering what many of you have found super helpful to have and how yours is set up to make things move as quickly as possible.
Anyone like to share their setup ideas and what works well for you?
Thanks
Tom
Old 07-08-2012, 10:10 PM
sartis sartis is offline
Default Re: Share Your Favorite Transport Setups..
I have an artist control and would enjoy seeing other peoples setups as well.
Old 07-08-2012, 11:14 PM
Ryan Young's Avatar
Ryan Young Ryan Young is offline
Hopefully these captures are explanatory enough :) I'm mostly a post-production guy and I use these primarily for my dialog editorial and during the mix. I use a combination of hotkeys, macros, window layouts, and memory locations. Hope these give some ideas to you.
Here's an old template I made, but it shows what it looks like on the unit.
Surface - Page 1
Surface - Page 2
Touchscreen - Page 1
-Ryan Young
•2019 Mac Pro 3.5 GHz 8-Core Intel Xeon W - 48 GB 2666 MHz DDR4 (OS 10.15.5) •HD Native PCIe, HD Omni, 192 I/o, Pro Tools Ultimate •Avid S3 + Dock •Blackmagic Intensity Pro (HDMI) •5.1 Room with JBL LSR4300 series
Additional Systems
•2010 Mac Pro 2 x 2.66 GHz 6-Core Intel Xeon - 48 GB 1333 MHz DDR3 (OS 10.14.6) •HD Native PCIe, 192 I/o, 96 I/o, Pro Tools Ultimate •McMix (x4), McControl (x1), JLCooper Surround panner for D-Command ES, Avid Control •Blackmagic Intensity Pro (HDMI) •7.1.4 Room with JBL LSR4300 series
•2017 MacBook Pro 2.8 GHz i7 - 16 GB 2133 MHz LPDDR3 (OS 10.14.6) •HD Native TB, HD Omni, Pro Tools Ultimate •McMix (x1), McControl (x1), Avid Control * or * D-Command ES Main Unit •Fed into whichever system is the main system
Old 07-08-2012, 11:43 PM
Only slightly off-topic:
Is there a way to take my personal setup to a different studio? Is there a way to export/import the setup and then import a page into the other control without wiping the custom settings on the other unit?
Also:
How can I move my softkey sessings from page 135 to page 1 without manually setting everything up from scratch again?
Cheers,
frank.
Old 07-09-2012, 07:03 AM
JR Fountain JR Fountain is offline
On the soft keys mine looks like this...
Preview - Suspend - Latch - Touch - Trim - Read
On the number pad it's...
Write to end - Continuous (No Scroll w/Shift) - Enable plugin
Punch Preview - Enable volume - Enable send volume
Auto Match - Enable pan - Enable send mute
Mem Loc - Mem Loc - Mem Loc
Show all tracks
I'm a post guy as well. Hope that helps.
JR
J.R. Fountain
credits: www.imdb.com/name/nm0288354/
system: Mac Studio Ultra, 128 GB RAM, macOS 13.6.1, MTRX Studio, S3 / Dock, PT Ultimate 2023.12
Old 07-09-2012, 09:44 AM
Ryan Young's Avatar
Yes, you can find your user set here:
Macintosh HD>Library>Application Support>Euphonix>UserSets>MC2User>MC_USER_SET__Roo t>Pro Tools 10Mac.xml (if you're using PT10)
It must be named "Pro Tools 10Mac.xml" or "Pro Tools 9Mac.xml" for it to work. If you're overwriting an existing user set, make sure to back everything up and rename properly.
I'm not too sure.
If you edit that "Pro Tools 10Mac.xml" file, you'll find something like this...
<NormalKeys>
<Control ID="SoftKey1" TYPE="SmartSwitch">
<Label FONT="Arial Bold" FONTSIZE="12.0000" NAME="Declicker" NOTEXT="1" TYPE="Text"/>
<CommandSet SUBTYPE="OneShot">
<Command ID="1" TYPE="Key">\p. \p1 \p* </Command>
</CommandSet>
</Control>
It's a bit of coding work but once you get the hang of it, you're just swapping whatever command is on a certain button and telling it to do what's on the other page.
-Ryan Young
Additional Systems
Old 07-09-2012, 12:05 PM
Thank you Ryan!
This is very helpful info.
Frank.
Old 08-29-2012, 08:12 AM
ivid ivid is offline
Im new to PT world (have been using Logic for years... just installed PT10 and making a slow migration over).
Is it possible to setup MCContol softkeys to insert a specific plug in (say in the first available insert slot of the selected track)?
ideally i'd like to have a screen of softkeys with my most-used plugins and use that to insert them onto a selected track. (btw, if anyone has figured out a way of doing something similar in logic -- would love to know too :) but dont think you can actually do that in logic. Looking at some of Ryan's screenshots -- looks like you have softkeys/hotkeys assigned to specific plugins. is that for PT?
Surface - Page 1
Surface - Page 2
Old 08-30-2012, 09:04 AM
Im new to PT-World (have been a Logic user for years and now making a slow migration to PT10).
Looking at Ryan's screenshots - looks like some of your softkeys (or hotkeys) are linked to specific plugins. Is this possible in mcControl w/PT10? ideally, what im trying to do is have a page of softkeys with a bunch of my mostly used plugins so that i can insert one of the plugins into the first available insert slot of the selected track. I dont think its possible in logicpro (if anyone has figured out a way to do it -- i would love to know as well). is this something that can be done with PT?
thanks
Old 08-30-2012, 10:58 AM
Ryan Young's Avatar
Unfortunately, you can't really pull up the RTAS plugin on a selected track, with one hot key. What I did was recalling a window configuration with AudioSuite plugins. Here's what you'd do, if you wanted to do that:
Open the plugin of choice.
Place the plugin (and everything else) where you want on the screen.
Store a new window configuration (lets use #1)
Set your McControl's button to perform a EuCon action of recalling window configuration #1 or have it execute the following keystrokes (for #1, perform the following keystrokes on the numerical keypad)
. 1 *
Name the button to whatever you'd like
Enjoy!!
-Ryan Young
Additional Systems
ARTIST TRANSPORT: Transport knobs do not light up when pushed smallchamber Artist Series 0 02-26-2013 05:36 AM
Locking MC Transport but NOT MC Mix's transport functions? zygmunt Artist Series 2 07-15-2012 09:11 PM
Share Your Favorite Music Avid Avid Scorch (iOS) Forum 0 06-08-2011 11:32 PM
DIGI 003 Transport vs. computer screen transport ostrange 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 01-10-2008 12:38 AM
Share your favorite sounds. jonnyrocker Tips & Tricks 0 03-13-2003 08:29 PM
