Old 06-22-2011, 05:06 PM
Siegfried Meier Siegfried Meier is offline
Default Slate Trigger Outputs
Hey guys,
Does anyone know if the samples in Trigger can be output to separate aux inputs so that you can have Pro Tools faders for control of each track/sample?
I know Battery works this way as well as BFD, but I cannot figure out a way to make Trigger do it - perhaps it can't?
Thanks!
Sig
Old 06-22-2011, 05:36 PM
WildHoney WildHoney is offline
Default Re: Slate Trigger Outputs
Originally Posted by Siegfried Meier View Post
Hey guys,
Thanks!
Sig
You mean have Snare direct, Snare OH, Snare rooms come up on separate PT faders?
Old 06-22-2011, 05:45 PM
Correct! Or, load in multiple direct samples and have them come out on separate PT faders, same thing.
Thanks!
Sig
Old 06-22-2011, 05:49 PM
Thanks!
Sig
Pretty sure you can't do that. Workaround by duplicating the track off of which you want to trigger and load your Trigger samples one per track on each of those duplicates.
Old 06-22-2011, 06:07 PM
Ya, that certainly works. Just a workflow thing, as well as CPU usage I would imagine - ie. 1 plugin with multiple samples loaded likely takes less CPU than multiple instances loaded, I would imagine?
Thanks,
Sig
Old 06-22-2011, 06:52 PM
Thanks,
Sig
I'd imagine you're right about that. Still, doesn't seem to bog down my system all that much even when I use that workaround for 4-8 tracks. And if you're willing to print them. . .
Old 06-22-2011, 08:57 PM
Dizzi45Z Dizzi45Z is offline
I have asked for a feature request like that to Slate Digital. I'd recommend that you also send a request. The more requests, the better.
recording.guru : FREE Pro Tools Tips and 19 Video Basic Training Course
Pro Tools HDX 2023.9
Mac Pro 7,1 3.2 GHz 16-Core Xeon W
160 GB RAM
macOS 11.7.4
Noisebox Studios -Utah Recording Studio
Old 11-26-2011, 10:43 PM
Guy McDude Guy McDude is offline
Has the output request been implemented?
Best,
Sean
Sean McDonald
Red Medicine Recording LLC
Sofa King Music Services
http://www.seanmcdonald.com
Old 11-27-2011, 10:12 AM
Nope, and never will be I'm told. Slate is an audio processing plugin, NOT an instrument, and thus will never have this feature.
Old 11-27-2011, 11:05 AM
guitar486 guitar486 is offline
Another workaround, but one that will save you in the processing department is just dial in your triggering and duplicate the track, load up all of your different samples and print them to new audio tracks. If what you want is separate processing control for multi-layered samples this is probably your best option.
----I was thinking of taking a solo in the bridge.
-Nah, I don't think that would sound good.
----Ok, well how about just a series of cool riffs?
Mac Pro 2008 (Harpertown) -- OS X 10.8.2 -- 16GB RAM -- WD Black Drives -- UA Apollo Quad -- Pro Tools 10 w/ CPTK
Slate Trigger 2 (AAX 64 / 32 & RTAS) crizdee AAX Plug-ins 12 10-15-2013 01:53 PM
Slate Trigger questions bonzerboy The Drum Room 1 12-11-2012 03:32 PM
FYI - Slate Trigger EX jmitchell1532 Pro Tools 10 0 12-10-2012 08:55 AM
for all Slate Trigger users... elicious General Discussion 1 08-15-2012 04:57 PM
Slate Trigger Ex to Platinum Upgrade $50 MikeLip Windows 0 02-20-2011 03:44 PM
