Re: track metering does not show panning
The contribution of a track is metered via the stereo buss or the track's subgroup master meter. And no, it wouldn't make things simpler, it makes things more complex because you're unnecessarily having to switch metering modes. With pre fader, it's all right there in front of you at all times. Meter shows level with processing, fader and pan show contribution, group and buss meters show result. Soloing a track in SIP allows you to see one track's contribution. Post fader metering hides what's happening with your inserts. You can be clipping or near clipping and not know it. It also means that the meter and physical position of the fader are showing you the same thing. Why would you ignore an important thing in order to see the same thing twice? Doesn't make sense. |
- Intel 14900K/NzXt Kraken Elite/64GB Kingston DDR5 6000 mhz (32x2)/ Asus Pro Art Z790/Asus 4090/Win 11 Pro 23H2/UAD Apollo 8 x2 w TBolt 3 card u/g/UAD Twin X. |
Post pan metering doesn't exist in PT of course. I made my case with specific reasons and examples. I was hoping to learn something here. |
As to the reasons for post fader metering and pan readout I've already made my reason(s) known on that. The line of 'that's the way it's been done before and must be done like that in the future' reminds me of the line those of us of a certain age remember hearing from our parents. And that goes: 'just because everyone else is doing it doesn't mean you have to do it'. |
Only thing I could find was Post #8 mentioning something about a signal being unbalanced and needing panning correction. Ironically this would support pre fader metering because you'd see the imbalance and correct it with a Multi Mono Trim plugin in slot 1. Then use the knobs to place it where you want it in the mix. Still interested in good reasons for post fader metering. And answers to the issues like: 1. clipping being hidden from you 2. two controls showing the same info right next to each other 3. in the mix window tracks with audio showing as blank if the fader is pulled down |
I give up - explained it as best as I could why I want what I want. And I have no need to justify it to you any further than I have. Like I said - we each work different; not saying there shouldn't be prefader only but we should be given the option of post fader operation as well. It's one extra button to enable an option - you'd still have the ability to work as YOU want. Sure beats having extra plugins for metering that one shouldn't have to use and clutter up the gui.
I'm outta here. |
Alrighty. Hopefully someone else will chime in.
I'm very confused by this string.
I was taught to use pre-fader metering when tracking to see the actual signal level when you're recording. I was taught to use post-fader metering when mixing, to see the actual effects of plugins on your individual track and mix. Are you guys saying that this is not the recommended procedure? |
Track show/hide markers disable track record status | BigBangPost | Post - Surround - Video | 4 | 03-27-2013 08:03 PM |
5.1 track lay out, routing, metering question | vudoo | Post - Surround - Video | 3 | 03-29-2012 07:45 PM |
question on track metering | yoerik | Pro Tools 9 | 0 | 06-07-2011 12:56 PM |
Panning one track, pans another track too. | pindebraende | Post - Surround - Video | 2 | 03-15-2011 03:48 AM |
Why is track metering now so different?!?! arrgh! | Mt.Everest | Pro Tools TDM Systems (Mac) | 37 | 08-08-2004 06:36 AM |
