Go Back   Avid Pro Audio Community > Legacy Products > Pro Tools 2020
Old 04-18-2020, 10:20 AM
Evermore Evermore is offline
Default Re: Sampling Rounding Bug and Workarounds - Pro Tools 2020.3
It's troubling to see what users are doing to workaround the bugs especially considering that these are standard and basics functions within any DAW. Hopefully some of the workarounds I provided are helping out.
Yes, having PT 11 and the latest version might just be the best workaround. I would definitely use PT 11 just to compose and arranges my projects.
Pro Tools 2023.3
Monterey 12.6.3
iMac i7 4.0
Apogee Symphony IO mkii
Old 04-18-2020, 04:33 PM
Kuras77 Kuras77 is offline
Evermore, thx man for that topic - I really hate Avid for that bug
This is very annoying especially with midi. Seriously Avid: DO SOMETHING WITH IT!!!
Old 04-20-2020, 11:04 AM
No problem man! Hope it's helping you out.
What would definitely help out is if you can say a bit of what you're doing when this bug affects you and how you are workaround it. This should be helpful for Avid. Just a thought.
Pro Tools 2023.3
Monterey 12.6.3
iMac i7 4.0
Old 04-20-2020, 11:33 AM
Ok, so after further testing, I can report that automation is also affected
I will provide an update with vids demonstrating what happens to Automation.
Pro Tools 2023.3
Monterey 12.6.3
iMac i7 4.0
Old 04-20-2020, 11:59 AM
take77 take77 is offline
MIDI notes are also getting misaligned randomly when doing tempo changes as well.
I'm to the point where I am just going to readjust the misaligned notes after I have a final MIDI arrangement rather than as I go.
Anyways, here is a full MIDI production with some guitar audio that I had to constantly re-alighn throughout the session.
It was already enough work doing the drums & chords note for note in the piano roll.
I'd like for it to be shared and enjoyed after all the painstaking yet determined effort. [sighs]
Regards,
Mike
https://soundcloud.com/rockexotic/es...ndtrack-medley
  #16
Old 04-20-2020, 01:33 PM
PMF Media PMF Media is offline
Yep, big +1 from me! I gave up using PT for MIDI ages ago, all my arranging is done in Logic then exported to PT fro editing and mixing - pesky I know, but also kinda "old school" - breaking up the tracking/arrangement and mix process, I kinda like the different head space.
As far as the audio side of the "sample rounding" bug goes, for me it been around since v11, I never had any problems in v10 and earlier, man, I long for the day that I can once again use cmd+D in shuffle mode and accurately copy clips and have align properly to the grid
The way I work around this is to option+drag a clip while in "slip" mode, drop it somewhere random on the time line then switch to "shuffle" and slam it behind the the previous clip, this seems to work 100% of the time with audio but... I work exclusively at 24bit 44.1khz(thought I'd mention that as sample rate and tempo seem to also play a part here).
This bug has been around sooooo long now, I doubt Avid even consider it worth fixing... a real shame, it's usually the 1st thing I check when I upgrade to a new version, oh well, we live in hope
  #17
Old 04-20-2020, 03:01 PM
foxes's Avatar
foxes foxes is offline
Avid are taking the p!!!!!
You are so right, this is a “standard and basic function”
iMac 27" Late 2013 3.5Ghz i7 32GB Ram 3TB HDD, 1TB SSD Samsung 850 Pro, Movaje 10.14.6, Pro tools 2021.7, 2021.3 & 2020.12 installed. UAD Apollo 8 Quad & Satellite Quad, Reason 10.4.1 & Reason Suite 11.3.9, Logic Pro X 10.5.1 (need to upgrade to Catalina for LPX10.6), plugins & VI's by practically everyone. G-Tech Mini 1TB HDD, 3 x 1TB Glyph GT050Q, Lacie Rugged 500GB & several assorted drives.....lots & lots of hardware synths & outboard
https://soundcloud.com/2b3productions
  #18
Old 04-24-2020, 11:58 AM
Why should anyone have to give up on a function that every DAW has working perfectly? This is anything but embarrassing for a company.
I've only been using Pro Tools for around 3-1/2 years and was not aware that the bug was around for so long for audio.
You can get the same results by using the Keyboard shortcuts "Snap to next & previous". This way you wouldn't have to change between shuffle, slip and grid. The only problem I see with your method or the one I mentioned is if some audio clips have been affected and change in length prior to editing. There really is no safe way to work in Pro Tools unless you figure out the Confirmed Tempos that work for 44.1khz.
Pro Tools 2023.3
Monterey 12.6.3
iMac i7 4.0
  #19
Old 04-24-2020, 12:00 PM
Regards,
Mike
Nice track! keep it up. Hopefully we'll see a fix sometime soon and allow us to focus on our music.
Pro Tools 2023.3
Monterey 12.6.3
iMac i7 4.0
  #20
Old 04-24-2020, 12:12 PM
Just did an update regarding automation and how its affected.
Pro Tools 2023.3
Monterey 12.6.3
iMac i7 4.0
Pro Tools 2020.1 off the wall Pro Tools 2019 141 11-28-2022 01:59 PM
Pro Tools (2020.3) on MacBook Air 2020 compatibility pellekuipers Pro Tools 2020 1 04-04-2020 08:01 AM
New Avid Link 2020.1 - launched today 1/16/2020 marianna Licensing & Accounts 8 01-16-2020 11:43 PM
Solutions and Workarounds For Accel TDM Studios To Use Pro Tools 11 relaxo Pro Tools 11 16 04-20-2014 05:53 AM
sample rounding error in pro tools 10??? DarkDayz Pro Tools 10 6 11-02-2011 03:22 AM
