Old 05-10-2020, 04:22 PM
LukeHoward LukeHoward is offline
Default Re: HDX Card not Showing Up in Core Audio or Pro Tools Ultimate 2019.12
Originally Posted by Producer112 View Post
When done with just chassis and no interface I get the same -1175 error upon launch and it quits.
Hmm. OK, another approach which may or may not yield useful results. Try starting Pro Tools, and have a look at the most recent log file in ~/Library/Logs/Avid (you can use Command-Shift-G to go there in Finder).
If my memory serves me correctly, I saw -1175 on starting DigiTest cold (without having started Pro Tools, and quit it, first). So try that too.
https://lukehoward.com/
Old 05-10-2020, 04:34 PM
Producer112 Producer112 is offline
Originally Posted by Southsidemusic View Post
Make sure the digilink is On the ilok key and also do a PRAM and restart the Mac.
We had a similar issue a few years ago on our HDX2 and after uninstalling the HD driver, not just run the installer over the omd HD driver and doing a PRAM we got it up and running. Double check your digilink is on the ilok key not just on the ilok account. Sorry if thats obvious but one post you said it is on your ilok account easily missed and we need to try everything.
Thanks for your reply.
Yes the Digilink I/o asset is on the ILok. I double and triple checked.
Tried un-installing HD Driver. Re-setting PRAm and also re-installing HD Driver. Issue is the same.
Old 05-10-2020, 04:35 PM
Might be time to ring the retailer you bought it from, or use your Avid Support Code.
Old 05-10-2020, 04:39 PM
I’ll check that out.
I’ve started a support ticket and will give this the college for another couple days. Won’t have much time to do much due to deadlines but maybe Avid is aware of something I’m not.
One thing that interesting.
I had my Previous Studio machine (a 2013 MacPro Trashcan on Sierra /Pro Tools HD 12.8 or something) and even though I had to run a thunderbolt adapater from the USB 3 Avid chassis to my Trash Can, it turned on right away, and was recognized in the system profiler.
However, I got the exact same DigiTest error and it wasn’t recognized by Pro Tools or Core audio. I did launch pro tools before I plugged the hdx card in to make sure it would launch and it did.
That would have been Hd Driver 12.8 I believe when I checked.
So something is obviously consistent with (2) totally different (but ironically stable systems).
Old 07-17-2020, 05:05 PM
waynejones253 waynejones253 is offline
I'm getting the same -1175 error when launching DigiTest with my HDX card in the Avid/Sonnet TB3 Chassis. Keep me informed if y'all got a solution.
Specs
Catalina 10.15.5
iMac Retina 5k 27 inch Late 2014
4gHz Quad Core Intel Core i7
32 GB RAM
ProTools Ultimate 2020.5
  #16
Old 07-20-2020, 03:34 PM
So i tried to hook up the HDX Chassis to a MacBook Pro with 2019.12 and still getting the same “DSI error occurred -1175” when attempting to run DigiTest. Now I wish I had a different chassis to test to see if it’s the card or the newer TB3 chassis itself.
  #17
Old 09-08-2020, 03:44 PM
C_F_H_13 C_F_H_13 is offline
I know this post is months old, but did you ever find a fix? I'm having the exact same issue right now and was hoping for some insight.
  #18
Old 08-16-2021, 09:39 AM
lichimin lichimin is offline
Hi!
someone find a solution?
i have the same problem with HDX and MTRX studio
i try to change the digilink too but nothing...
Thanks
  #19
Old 08-16-2021, 09:46 AM
creativecontrol's Avatar
What macOS version and what version of DADman? This Knowledge base article is also quite useful ->
https://avid.secure.force.com/pkb/ar...__2&popup=true
Jeff
Jeff Komar
Solutions
S6 FAQ
MTRX FAQ
  #20
Old 08-22-2021, 09:16 PM
B-Grade B-Grade is offline
This thread has been a lifesaver! I have had the HDX card not showing up, and the script has brought it back. Brought it back, that is until I reboot. I have tried the uninstall reinstall of the HD driver, resetting the Pram, to no avail. I never get any warnings or messages in the security control panel.
So any other ideas on how to fix this for real would be great. I don't want to have to do the script thing every time I reboot.
Mac Pro Rack - Ventura
PT 23.12
HDX - MTRX Studio
Mac M2 13" Air in the field
Pro Tools 2019.12 Ultimate Crashes 2019 Mac Pro rmccam Pro Tools 2019 11 02-28-2020 03:59 AM
FS: Pro Tools | Ultimate 2019.6 Juljan Buy & Sell 0 02-23-2020 09:51 AM
FS : Avid HD Native PCIE card with Pro Tools Ultimate 2019.6 Perpetual License Marc Hudson Buy & Sell 0 10-28-2019 06:33 AM
Pro Tools 2019 Ultimate - Sonnet X-IIIR - HDX Card Freezing priceless530 Pro Tools 2019 3 10-23-2019 05:43 PM
Pro Tools Ultimate 2019.5 and HDX Avid Technical Alerts 0 05-09-2019 01:55 PM
