Old 04-07-2012, 09:38 AM
pie55 pie55 is offline
Default external usb drive
Hello,
Can I use a tera byte external usb drive with protools 8? I'm using 88.2 sample rate. If so what model is recommended
thanks
Old 04-07-2012, 11:25 AM
Dism Dism is offline
Default Re: external usb drive
OS? Computer specs? Desktop/laptop? HD or LE? etc...
D
a n t h e I n c r e d i b l e S o u n d M a n
"Svetlana" v1 - 4.2GHz i7, 16GB RAM, OSX 10.7.4
Liquid Saffire 56 - PT10.2 - BFD2, VCC, Duende Native, Play 3.0
_C U R R E N T-D V E R B-S C O R E:515
Old 04-07-2012, 11:30 AM
Windows xp pro, Protools HD, desk top, AMd opteron quad core k8ndl mother board
Old 04-07-2012, 11:38 AM
If you have a desktop, why would you even want to record to an external drive?
At any rate, USB externals were never supported with XP and PT8. Sometimes even just having them plugged in could cause problems. If you absolutely have to use an external drive, make it FireWire.
D
Old 04-07-2012, 11:47 AM
Thanks,
One of my sata connections is broken and I need to transfer a few projects to a different drive. If I could record with the usb drive it would save me from moving the projects twice.
Thanks for you advice
Old 04-19-2012, 01:56 PM
Fullsound Recording Fullsound Recording is offline
I dont think you will even be able to record a 88.2 session on a usb drive. I would think the read write rate would be way to slow and throw you lots of errors.
www.fullsoundrecording.com
Seattle Wa
I voted at www.deardigi.com
Old 04-19-2012, 05:04 PM
Windows XP does not support recording to USB drives. Windows 7 does. You can use a USB drive to transfer by saving the session to it(either by drag&drop, or by using Save Session Copy). Performance will be best by moving/copying to another internal drive.
Old 04-28-2012, 05:23 PM
Thanks guys. I got a sata to usb dock making back up easy
Why does Avid recommend external USB over external Firewire for audio drive? DJ Hellfire Pro Tools 10 10 03-29-2012 09:39 PM
Is an external drive superior to a 2nd internal drive for recording with Protools? beyoutofull1 Pro Tools M-Powered (Win) 4 03-03-2010 06:08 AM
External dedicated external hard drive JuanCarlos General Discussion 1 02-15-2010 03:11 PM
Backing up Audio Drive (External) and External HD Question JCWarrior Pro Tools TDM Systems (Mac) 2 04-13-2008 04:42 AM
Why is my LaCie external 80 gig, 7200 rpm firewire hard drive an invalid drive to be Fucius General Discussion 4 03-19-2002 11:26 PM
