Old 02-26-2004, 07:20 AM
Orange Worker Orange Worker is offline
Default Have you ever burned?
Last night I installed the new Digi plugs (Bombfactory). I was working on a session, an applied the BF76 to an aux track. After a few minutes, my computer started to make an obnoxious buzz sound. So, I quickly turned off my monitors and plugged in a set of headphones. Then, I closed out of the session - still heard the noise. Exited from Pro Tools - still heard the noise. During all this, I smelled something burning (electrical). I thought the smell was coming from my monitors, but came to the conclusion that it was the computer.
My computer runs very SMOOTH, I've never had any problems with it. I use it strictly for audio only. Does anybody have any ideas on what went wrong? I've haven't turned on the computer since last night, but I'm a little worried that something is ruined.
Intel D845PESV
P4 2.53 Mghz
1 gig ATP Electronics ram
Win XP
PTLE 6.1.1
Reason 2.5
Kontakt (the current version)
Old 02-26-2004, 07:35 AM
scoobydoo scoobydoo is offline
Default Re: Have you ever burned?
WOW, better turn it off, umplug and open up the case and see what it was.
Thats happened to me when a power supply went on me...
Scarry.
You gotta get it in the mic!
Old 02-26-2004, 07:36 AM
where02190 where02190 is offline
If both dries were continuing to work, it's most likely a cooling fan. If you are computer savvy, open it up and manually move the fans, you may find one that feels stiff or uneven in it's rotation. If so, replace it. If not, you can try powering up with it open to locate the noise.
Otherwise take it to your locale repair tech, or contact the manufacturer if it's still under warrantee.
Old 02-26-2004, 07:41 AM
lemix's Avatar
lemix lemix is offline
Sorry to hear...on the brighter side though, there are only two (well...)likely causes;
1)power supply
2)CPU fan
These are fairly inexpensive to replace.
Open the case and look for obvious burn signes.
good luck,
cheers,
Andrew
W7 pro 64_i7 3930K_16GB_ Nuendo 6.5.4-7.1.3 / PT 12.4 ------Mac Mini OSX Lion_PT 10.xx
Allen&Heath GS R-24M_ full rack of vintage analog boxes _UAD2_Nugen_iZotope_Melda_Waves_Plugin Alliance_DMG and more
2.0 and 5.1 monitoring
Old 02-26-2004, 08:59 AM
da BaSsTaRd! da BaSsTaRd! is offline
i had a psu blow up in my face once. thanks to my ninja reflexes, i only lost my eyebrows...
i love my apple iPhone!
Old 02-26-2004, 07:22 PM
Hello again,
I opened up my computer today, and both fans are fine. When I turned my computer on, sure enough, the noise was still coming through the head phones when at the desktop, but no burning this time. I opened a session, but couldn't hear any audio at all (when I record enabled a track, used midi, or tried to play recorded audio), very strange, just the "buzz". I emailed digi about this one...any more final thoughts, anybody?
I'm using the 001 box, didn't mention that in my last post. Any chances on the sound card being ruined?
~Henry
Old 02-26-2004, 07:51 PM
Something burned, and something doesn't work now - so I'd say that's a possibility.
Hello again,
~Henry
Quad 2.5 G5, 4.5G RAM
Burned in TC bdangler Post - Surround - Video 7 09-10-2013 09:14 PM
Help Help Help!!! is my pci card burned? cuba 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 06-30-2003 02:54 AM
burned a cd w/o dithering in LE rems 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 07-12-2002 10:21 AM
Anyone burned CDs on new G4 w/SuperDrive? el biciclista 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 7 08-27-2001 07:47 PM
clipping when burned to CD johnmazz 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 8 06-27-2001 02:40 PM
