Go Back   Avid Pro Audio Community > Legacy Products > Pro Tools 2020
Old 11-30-2020, 11:08 PM
DrewHarrison DrewHarrison is offline
Default Auto-Save Not Working Properly
I get PT crashes about 3-7 times a day on average, and I have it set to auto-save every 1 minute. However, after a crash when I check the backed up sessions the newest session is usually somewhere between the last 10 minutes and 45 minutes... not even close to every minute.
Anyone else getting this? I'm losing a lot of work here.
Pro Tools 2022.12.0
Mac Pro 2019
OS X Big Sur
Old 12-01-2020, 04:01 AM
crizdee's Avatar
crizdee crizdee is offline
Default Re: Auto-Save No Working Properly
Auto backup only works when the transport is stopped. so expect you were working with the session playing for 10mins or 45mins etc.
get in the habit of hitting save.
Chris
Producer, Engineer,
www.ukmastering.com
Old 12-01-2020, 07:59 AM
Southsidemusic's Avatar
Agree! We have had some problems aswell in the past with autosave as if we have big sessions running and automation etc the session could get problematic if autosave was trying to save.
We save every 3-5 mins by ourse๖ves and we know it will be done when sessions are stopped and wont get corrupted should a crash occur.
Turn it off and do the saves by yourself is my advice to stay out of the crash issue
Best Regards
Christopher
#thestruggleisreal
South Side Music Group
WEBHOME
Old 12-01-2020, 09:03 AM
Default Re: Auto-Save Not Working Properly
I'm usually 'in the zone' getting great mixes and automation done at the time. i.e., by best work, and then it's all gone.
How am I supposed to remember to stop and hit save when I'm in the zone? The world disappears and I am emersed in the music just moving faders, eq moves, automation, etc. Even if I set an alarm to remind me it would break the flow. Any ideas?
It needs to just save.
Pro Tools 2022.12.0
Mac Pro 2019
OS X Big Sur
Old 12-01-2020, 10:38 AM
crizdee's Avatar
Just stopping the transport for a second will allow it to save. I know what you mean and we've all had times when we get involved and forget, but just try to remember to save your work as you go and don't do too much or leave it too long.
If you have instruments that have samples and sound sets to save, this can cause the save to take longer and can cause issues itself.
Chris
Producer, Engineer,
www.ukmastering.com
Old 12-01-2020, 11:09 AM
What about using a macro that will hit Cmd+S at the interval of my choosing?
If I have to hold a "don't forget to..." statement in my head as I'm trying to listen to what the song wants, I'm not listening to what the song wants, I'm instead listening to the statement "don't forget to..."
Pro Tools 2022.12.0
Mac Pro 2019
OS X Big Sur
Old 12-01-2020, 04:12 PM
It happened again twice in the last hour, last saved over 15 minutes ago after lots of changes. I'm trying to remember to stop and save, but I'm listening to music. If I remember to save I forget to listen to the music. This is nuts.
Pro Tools 2022.12.0
Mac Pro 2019
OS X Big Sur
Old 12-01-2020, 04:36 PM
Ctrl-S is a second-nature reflex for many of us I don't know if this relates to your rig, but I had a session today that threw an error message that it couldn't do an auto-save because one of the .bak files was corrupted. At first, I thought that's easy....I'll just delete that .bak file. But when I went to the Session Backup folder, it would not open(and gave me another error). Then I thought, I'll just delete the Backups folder, but that threw the same error message. After thinking about it for a few minutes, I tried to rename the folder and that worked(I added xxx in front of the folder name).
I also opened the session and did a Save Session Copy so I had a complete backup(but without any Auto-backups). Later, I opened both versions and each created a new backup folder and things worked fine after that. I still can't delete the renamed folder, but the newly created backup folder has a dozen fresh backup files from today.
Old 12-02-2020, 04:29 AM
I know I've joked about but it really isn't a joke - this is why the thumb and fingers of my left hand are bent in the shape of cmd-S and it's auto muscle memory to do a save as often as I can. It's part of my 'in the zone' thing.
Jack
QAPLA!
Old 12-02-2020, 05:10 AM
crizdee's Avatar
First, you could write a keyboard shortcut in the Mac prefs/keyboard/shortcuts and under app shortcuts you can assign the command "Save As..." exactly as it is written in the pro tools menu Save As... then assign this command to something easier maybe Shift+Z which are next to each other.
Or get something like a shuttle or games controller that you can assign commands to and use that.
Fortunately my control surface has a flashing red button
Second, You need to troubleshooting why you're system is crashing so often. what are the crash logs saying?
Chris
Producer, Engineer,
www.ukmastering.com
Pro Tools First will not save my tracks properly Itsjake Pro Tools | Intro Discussion 6 04-27-2019 04:55 PM
Bug? "Save A Copy In" not working properly GeorgeA Pro Tools 12 5 09-15-2017 11:10 AM
(-50) ERROR on Save / Auto Save oldrake macOS 1 10-14-2013 03:30 PM
"Save Session Copy In..." not working properly Meads Pro Tools 11 2 07-20-2013 09:15 AM
HELP! 'Save Copy In" not working properly in v.7 Sebastien Bedard Pro Tools TDM Systems (Mac) 1 04-06-2006 09:51 AM
