Windwos 10 Eucontrol Autostart not working
Hi all,
I run the latest Avid Artist Series Software on my Win 10 Pro system. Unfortunately the Autostart option does not work. I can see Eucontrol in the autostart list (in task manager) and it is activated. Still it does NOT start automatically upon windows boot. Any ideas? Thx, Ernst |
Re: Windwos 10 Eucontrol Autostart not working
I'm on Windows and it works OK. Maybe you have it in another Startup location for earlier ?
Use the Windows key + R keyboard shortcut to open the Run command. Type the following command to open the Startup folder and press Enter: shell:startup Click OK. It shouldn't be in there |
Hi you,
Eucontrol IS in the startup folder (which contains a lot of items in my case - maybe this is to blame?) - and I managed (using 3rd Party Software) to make it start now (by delaying the its start a little). What is annoying still is that it requests authorization now (the usual Win 10 confirmation because of UAC). Are there ways to avoid that without deactivating UAC?) THx, Ernst |
Please remove it from that startup folder. its an old location. Then use the EuControl option on the taskbar to enable it to auto start. Are you an admin user or standard ?
Hi you,
I removed it from the Autostart folder. And I checked the relevant Item in the Eucontrol menu.I have administrator privileges. Eucontrol now does not start automatically. When I manually start it again the checkmark next to "Eucontrol" (Start automatically / the menu item) is DISAPPEARED. Can it be that something is wrong with the rights to access locations on the system drive? My user has admin rights and appears to have full access... Hm..... Last edited by Elien; 11-15-2019 at 07:02 AM. |
If you open Task Manager and look at the startup tab you should see it there. You may need to switch tabs to refresh. See if checking and unchecking it in EuControl adds and removes it
Hi you,
yes it does appear and disappear in the autostart tab of taskmanager when i check the menu item and uncheck it. When I reboot windows eucontrol still does not autostart! Thx, Ernst |
Hello,
I sum up and add some information: Even though the checkmark is selected, Eucontrol refuses to start automatically. The checkmark is also sometimes not remembered correctly. Switching it on and off and checking in the task manager shows that it appears and disappears there correctly. I tryied with UAC settings down to the lowest possible degree. Still not working. Both MCClient and Eucontrol are set to "run as administrator". Eucontrol persists to ask for permissions! Under the activated (originally hidden) administrator account it works as expected. My user account belongs to the administrator group. Still the difference! (Additional information: It is a local user, so not linked to a microsoft account - but this should not make any difference, the admin acound is also local). Any ideas what I can try? Maybe modify a registry key? Which one? Thx, Ernst |
Which account did you install EuControl from ?
Hi, I installed it from my normal account which belongs to the administrator group.
Ernst |
Assignments in EuControl not working | Cryos | Avid S1, S3, Dock and Control App | 6 | 07-14-2018 03:15 PM |
Eucontrol 3.1.2 not working on 10.5.8 | mmoeding | Artist Series | 0 | 03-25-2014 06:28 PM |
2 plug-in windwos at the same time? | der daniel | Pro Tools M-Powered (Win) | 3 | 07-03-2006 02:01 AM |
MTPAV and MAC - Autostart probs | Petra Pan | Pro Tools TDM Systems (Mac) | 4 | 06-06-2001 09:34 AM |
autostart virus - need advice! | coaster | Pro Tools TDM Systems (Mac) | 4 | 11-08-1999 10:34 AM |
