Go Back   Avid Pro Audio Community > Pro Tools Software > Pro Tools 2018
Old 02-17-2018, 08:54 PM
SupreGlu SupreGlu is offline
Default Man Overboard! (will PT2018 interfere with Logic?)
lol I jumped ship from PT about 2 yrs ago and have been using Logic Pro X (latest) and OS X (latest) with perfect performance.
One thing I always hated about PT was the ongoing will this work with that updates and issues. Tht said I do love PT and am thinking about installing on my current (perfectly working) system.
So the question is....will Pro Tools (latest) conflict with anything on my system (e.g. logic) and will it work flawlessly with any interface?
Old 02-17-2018, 09:06 PM
Folks here cannot guess what OS version you are running.
There generally should not be a conflict between LogicX and Pro Tools as long as those apps are supported on the OS version and all plugins are also compatible. Many of us here run both both of those DAWs.
Up the top of every DUC page are links that take you to the product compatibility matrix. *you* need to get used to checking Pro Tools is supported on the macOS version you want to run. And then you need to check all third party plugins and interface drivers are also compatible, for both DAWs. Bookmark the pages on those vendor sites so you can find them easily.
Nobody here can ever promise you that something will work flawlessly, so that is the wrong question to ask. All people can tell you is if the vendors claim to support some combination or if it is working for them. Interfaces are critically dependent on driver support on the OS... you have to pay careful attention to that.
Have a backup/recovery plan before doing stuff so you can recover when software or you screw up.
Old 02-17-2018, 09:50 PM
Default Re: Man Overboard!
Using only Logic I always run latest everything. I suppose an advantage of having Logic. Whereas was always horrified of upgrades of (like you say.. drivers, os, pt). I hear what you are saying though...guess there is no perfect solution. good to hear many are running both.
Old 02-17-2018, 09:51 PM
Oh be careful you can easily burn yourself badly with Logic and third party plugin issues...
Old 02-18-2018, 07:13 AM
john1192 john1192 is offline
Default Re: Man Overboard! (will PT2018 interfere with Logic?)
you could "rent" pro tools for a month and see what happens .. make a bootable backup your system fully before though to be safe ..
Mac Pro 6-core 3.33ghz (2012) 24gb ram 256gb SSD -OS 10.12.6 for PT 11.3.2 & 2019.6 last version
Logic Pro X latest version
RME BabyFace Pro
Macbook Pro july 2014 2.5ghz 16gb ram 512gb SSD - OS10.14.6 - PT 2019.6 Ended here ..
RME BabyFace Pro
Old 02-18-2018, 07:51 AM
BScout BScout is offline
I have Logic Pro X (latest) and Pro Tools HD 2018.1 on the same system running Sierra. No Problems. (of course you can't have them open at the same time if you intend for Logic to use the same audio interface as Pro Tools)
Old 02-18-2018, 12:25 PM
Do they both work with system audio?(Built-In)
Old 02-18-2018, 12:31 PM
Yes. But most folks are going to use them with professional audio interfaces.
How well they will work running at the same time is another issue. Hopefully not what you are asking.
Separately, I'm sure but I don't run that way. My HD system runs on HDX and my Logic runs on RME. So in my case, I can have them both open at the same time since they aren't using the same audio interface (and my system sounds also run on the RME.) I also keep Izotope RX6 Adv running out the RME too at the same time.
Basically Pro Tools does not like to share audio interfaces but Logic doesn't care. So as long you don't open Pro Tools while Logic is open, you are fine if Pro Tools' engine is set to the same interface. If you do open Pro Tools while logic is open, Pro Tools will try to grab another interface on the system. Big thing is they are all stable and can work on the same system -- just have to be aware of this.
Old 02-18-2018, 03:56 PM
TNM TNM is offline
same here.. I have cubase 8.5 full, 9.5.10 demo, Logic 10.4, S1 3.5.5 and PT 2018.1 and there are zero conflicts.. In fact, i've even had PT, Cubase and Logic all open at the same time using the same outputs (awesomeness of core audio) and switching between them. All works fine.
I left Logic to go to PT but still have many projects to convert, thousands, so leave it installed for when i have the time. I am actually enjoying using UAD plugins all over the place now and having automation in perfect time, which is impossible to do in Logic on audio tracks and instrument track outputs 1 and 2. Latent plugins cause automation in logic to be shifted by the total amount of latency in that signal path. Been happening for 10 years. I had had enough.
So much for logic's perfect performance
https://www.dropbox.com/s/nsjaup2zrs...Delay.mov?dl=0
-iMac Pro 3.2ghz 8 Core, 64GB Ram, Vega 56, OS 10.14.6/Win10 Pro, TB3 Dock & 4xSSD, UA Apollo x3 + Octopre x3, Microlite x2, Midi Synths galore, PT 2019.12
-MBP 15" 2.8ghz 4 core, 16gb ram, 750M, dual boot OS 10.13.6/10.14.6, On board analog audio out, PT 2018/2019
-MSI Alpha 15, Win 10 pro, 16GB ram, AMD 3750H quad core, AMD 5500M, Mbox 3 (can finally use it LOL!).
-Whenever I launch Pro Tools, I get wet.(™)
Dissapointed with PT2018 Edit Window MarceloBcn Pro Tools 2018 7 02-06-2018 06:24 AM
PT2018.1 - Disable Tab to MIDI note end? cshaw Pro Tools 12 11 01-26-2018 05:02 PM
if i install emu soundcard will it interfere with samrisio 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 03-01-2005 06:26 PM
Does Zone Alarm interfere with pro tools LE Aussie Adam 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 16 05-12-2004 07:55 AM
