Old 08-19-2015, 04:27 PM
SupreGlu SupreGlu is offline
Default set automation point at exactly zero
how to set automation point with pencil at exactly zero
Old 08-19-2015, 05:30 PM
The Weed's Avatar
The Weed The Weed is online now
Default Re: set automation point at exactly zero
Do not use the Pencil Tool for single automation points; set, move and delete automation points with your mouse/left click and, on PC, Ctrl (make), Alt (delete) and Ctrl+Drag to move in fine increments.
Cheers,
non-union national read at a reasonable rate
Demos: brucehayward dot com
Source-Connect: brucehayward
Old 08-19-2015, 08:31 PM
but how do you land on / set point on zero regardless of tool?
Old 08-21-2015, 06:09 PM
The Weed's Avatar
When you move an automation point, are you not seeing the dB changes in a small "box"?
Old 08-21-2015, 06:13 PM
mesaone mesaone is offline
After rolling this over in my mind, I think it would be neat to have an automation event list (similar to the MIDI event list already in PT). That way, time and value of each automation breakpoint could be edited. Maybe even exported as CSV or other text-based format, if there's a need for it.. Imagine a world where moving automation between DAWs can be done without an AAF file.
I'll search IdeaScale to see if this is already requested. If not, I might enter it myself.
Pro Tools HD 12.4, Pro Tools "Vanilla" 12.4, Artist Transport, 2x Artist Mix
Studio Blue: RME UCX, Win7 Pro, i7 960, 16GB || Studio Green: RME Babyface, Win10, i7 7700HQ, 16GB
Old 08-26-2015, 06:45 PM
V5V's Avatar
V5V V5V is offline
Please do. I would like a way to enter a numerical value for EXACTLY where to place an automation change -- time and value.
If you provide a link to the Ideascale posting here, we can all make sure we vote up the right listing.
If you don't have time, lemme know and I'll do it.
Lorin Schultz
V5V Audio
Vancouver, BC Canada
Old 08-26-2015, 07:39 PM
Done.
http://protools.ideascale.com/a/dtd/...st/204061-3779
Old 08-26-2015, 10:35 PM
V5V's Avatar
V5V V5V is offline
Thanks! I've added my vote. I'd appreciate it if anyone else who likes the idea of an automation event list would vote for it too.
Lorin Schultz
V5V Audio
Old 10-28-2015, 11:57 AM
it is amazing that i can not use a key command to land a point on zero - like in NLEs and almost any other app you can use modifiers to "set at default" and to "constrain" while moving...major time waster!
Old 10-28-2015, 02:26 PM
Larold Larold is offline
Option Click not working?
Four-point automation w/fades? bleen macOS 1 02-22-2014 05:47 PM
Move Automation to Sync Point quoid macOS 2 02-26-2011 10:11 AM
Key-Command for dropping automation point? Floydio Tips & Tricks 9 05-11-2009 04:56 AM
Automation point resolution Centurion Pro Tools TDM Systems (Mac) 1 01-20-2003 08:58 AM
Automation point moving Sparks 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 12-22-2002 03:46 PM
