Old 12-19-2012, 10:56 AM
mark.dixon909 mark.dixon909 is offline
Default MBox Internally Recording Question
I have Pro Tools 9 & an Mbox running on OS X. I would like to record from another application running on the same machine. Is it possible to route the audio generated from a second application, internally into Pro Tools?
Old 12-19-2012, 11:08 AM
Craig F Craig F is offline
Default Re: MBox Internally Recording Question
maybe, look at ReWire or Soundflower
Thank you,
Craig
Old 12-19-2012, 02:46 PM
I doubt you will stream directly into Pro Tools, but there are several programs that can record, so you can IMPORT into Pro Tools. Although, if you select to use the onboard audio(with PT9 or 10), that may work fine. Another option would be to route the onboard audio output to Mbox inputs(essentially what I do by calling up internet on a separate machine and feeding its audio to a pair of line inputs on my 003.
Old 12-20-2012, 01:10 PM
The Dougfather The Dougfather is offline
If it's a non audio app then check out Audio Hijack Pro, a killer piece of software for recording anything that passes through your soundcard.
iMac i5 2.8GHz, Macbook Pro 2.4GHz, Pro Tools 10/11, MOTU 828mk2, Presonus Digimax FS, Presonus Firestudio Project, TC Konnekt 24D
iCON Photography
Recording internally using MBox3 mark.dixon909 macOS 0 02-04-2012 04:51 AM
Mobile Recording (mbox question) paul_g 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 10-28-2010 10:22 PM
Recording streaming audio / internet radio internally ? chrisdee 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 09-01-2010 08:32 AM
Mbox 2 Mini and recording question. kidstretch 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 12-02-2007 08:57 AM
newbie question about recording on through mbox jjblugrassy Tips & Tricks 2 08-12-2007 09:36 PM
