Old 11-25-2012, 03:15 PM
MaxPayne MaxPayne is offline
Default Pro Tools 10 Native a good alternative?
Hi guys,
i´m using Cubase right now on my PC. I record my stuff and mix it. Everything works fine... But I tested Pro Tools 10 and I love the workflow on it. Somone in the internet says this in a DAW comparison about Pro Tools:
"Pro Tools only stands out after spending $10k for HD. The sub-standard versions that run under $3000 (depending what hardware you bundle) only give you a tease of ProTools, and really taxes your CPU buffer when using 3rd party plugins and can disrupt sessions(although this happens with all DAWs, its more common in ProTools)"
Is that true? So I´m not able spend 10k for a HD system. But is a Native version so bad?
My system is a i7Quad 3,0ghz with 16gb ram.
Thanks in advance!
Max
Old 11-25-2012, 03:47 PM
nst7 nst7 is offline
Default Re: Pro Tools 10 Native a good alternative?
That person is wrong and doesn't know what they're talking about.
The only issue with Protools vs. other DAW's is when using a lot of virtual instruments. This has been the case for years and applies even when using the top line HD systems. Avid is working on fixing that, but for audio, it's fine.
Old 11-25-2012, 03:54 PM
Thanks so much.
Old 11-25-2012, 04:21 PM
soybalm soybalm is offline
The RME stuff works great on a Mac, probably a pc as well.
Dave Cournoyer-guitarist-project studio
Mac Mini late 2012, i7, Sierra
16GB PT10.3.10HD PT12.5.2
Apogee Mini-Me firewire.
No more TCE in 11 - what's a good alternative? Meads AAX Plug-ins 83 09-17-2013 02:06 PM
Good RTAS Ultrabeat/Redrum alternative ? Ru_C Pro Tools TDM Systems (Mac) 4 06-01-2011 06:56 AM
Good alternative to waves L2 ? Ru_C Pro Tools TDM Systems (Mac) 18 09-20-2007 08:25 AM
Alternative to Pro Tools please? robertnorris 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 20 01-21-2007 09:35 AM
OT: Any good Alternative to Auralex Foam ? Ru_C Pro Tools TDM Systems (Mac) 14 01-19-2007 05:50 PM
