Old 01-09-2011, 03:47 AM
onepercentfree onepercentfree is offline
Default Mac OS X v10.6.6 Update Combo (new jan.6)
http://support.apple.com/kb/DL1349
OK who is willing to test this one.
Very curious cause i went back to 10.6.4 after 10.6.5
proved to just add weight for nothing really.
Old 01-09-2011, 05:29 AM
JFreak's Avatar
JFreak JFreak is offline
Default Re: Mac OS X v10.6.6 Update Combo (new jan.6)
Never ever update OSX until Avid has blessed the build. Not ever, period.
Janne
Old 01-09-2011, 10:42 AM
Park Seward's Avatar
Park Seward Park Seward is offline
10.6.6 is primarily for the addition of the App Store. It as nothing to make PT any better so there is no advantage in upgrading.
Park
The Transfer Lab at Video Park
Analog tape to Pro Tools transfers, 1/4"-2"
http://www.videopark.com
MacPro 6 core 3.33 GHz, OS 10.12.1, 8 GB RAM, PT12.6.1, Focusrite Saffire Pro 40, PreSonus DigiMax, MC Control V3.5, dual displays,
Neumann U-47, Tab V76 mic pre, RCA 44BX and 77DX, MacBook Pro 9,1, 2.3 Mhz, i7, CBS Labs Audimax and Volumax.
Ampex 440B half-track and four-track, 351 tube full-track mono, MM-1100 16-track.
Old 01-09-2011, 11:15 AM
crustn crustn is offline
I have upgraded to 10.6.6
Until now, no problem with Pro Tools 9.0
Old 01-09-2011, 11:56 AM
I upgraded with the combo update as always on one of my macbook pros. All is still good for now. I also upgraded to Protools 9.0.1 and applied the midi fix. Everythings still seems fine.
Obsidian Dragon
Model Name: MacBook Pro
Model Identifier: MacBookPro14,3
Processor Name: Intel Core i7
Processor Speed: 3.1 GHz
Number of Processors: 1
Total Number of Cores: 4
L2 Cache (per Core): 256 KB
L3 Cache: 8 MB
Memory: 16 GB
MacOS 10.15.2 running Protools 2019.12.0
Old 01-09-2011, 12:02 PM
SixChurchStreet SixChurchStreet is offline
Default
Unless you want to check out and use the AppStore.
- Sent using Tapatalk.
Mac Pro 5,1 2.4GHz 8-Core 16GB RAM El Capitan | 2011 MacBook Pro 2.0GHz 4-Core i7 8GB RAM El Capitan | Focusrite Scarlett 6i6 Mk2 | Pro Tools 2018 | Studio One 3.5
Old 01-09-2011, 09:16 PM
VoteNetti VoteNetti is offline
I upgraded a few days ago. 10.6.6 fixed a very annoying bug with ATI 5770 graphics cards when connected via DVI that causes the mouse to be jerky and erratic. Monitor now works flawless. I worked on some vocals all day today and only had 1(one) crash. When I tried to spot some audio to its original postions Pro Tools crashed. Havent had any problems otherwise.
Netti
"Yup, I hear stuff."
Dual 2.4Ghz Quad "Westmere"
14GB Ram
OS X 10.8.4
PT 10.6.7
HD Native PCIe + HD i/o 16x16 + 192 8x8x8
UA 2192 Master Clock and Mix in/playback
Old 01-11-2011, 09:18 AM
riverwalk riverwalk is offline
Upgraded to 10.6.6 with PT9.0.0 and working fine. I also noticed a fix with the graphics card that had been causing a flickery screen on startup. the only problem I've had in PT so far was a flickering plugin window (a Waves C1). It's only happened once and caused no audio problems.
Mac 8-core, OSX 10.6.6, PT9, RME Fireface 800
Old 01-11-2011, 04:09 PM
jjtarnow jjtarnow is offline
I'm running 10.6.6 with PT9.01 via 003R with no problems thus far....of course the 003 midi driver delete was a total pain until I got the patch...now all is well.
Old 01-11-2011, 04:45 PM
Eric Lambert's Avatar
There will always be people who upgrade early,. There will always be people who have no issues with it, and also those who screw up their entire system. It's at-your-own-risk until Avid says "go" (though that doesn't offer any guarantees either).
Mac OS X v10.6.3 v1.1 Update (Combo)? gthm 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 04-23-2010 12:19 PM
How bad is it to not use Combo update? Dizzi45Z Pro Tools TDM Systems (Mac) 11 02-11-2010 10:25 PM
Mac OSX 10.5.8 combo update Growlyman 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 01-16-2010 04:11 PM
10.5.5 combo update... ebonyles 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 12 01-12-2009 09:23 AM
PT LE 7.3.1 NOT LAUNCHING AFTER 10.4.9 combo update ! HELP waterbedman 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 7 06-11-2007 05:11 PM
