Old 08-14-2010, 05:51 PM
Bren10 Bren10 is offline
Default Lost Communication With Audio Interface -6097
I have a DIGI 002 and a 3rd Generation Dual 2 GHz PowerPC G5 Power Mac running Mac OS 10.5.8. I just upgraded to Pro Tools LE 8.0.1cs2 from 7.4.x. Now, when I open a session with a moderate amount of plug-ns, Pro Tools is immediately sluggish and unresponsive, I get the spinning cursor which is also unresponsive, and I eventually get an error message that says "Lost Communication with Audio Interface... -6097" The message says to try increasing HW buffer size or reducing the number of RTAS plug-ins. I tried doing those things, and it didn't help. I went through the troubleshooting thread and did all the things it said to maximize my system performance - that didn't help. I made sure that I didn't have any old versions of any plug-ins installed - that didn't help. I did a bunch of other things that were suggested in the troubleshooting thread which didn't help either. I found a thread where someone suggested decreasing the number of processors in the playback engine to 1 instead of 2 - that didn't help. I also found a thread where someone suggested that it may be a problem with firewire ports, so I spent some time trying different configurations of plugging in my DIGI 002 and my LaCie firewire 400/800 drive - this didn't help either. Can someone please help me? As it is now, my Pro Tools system is virtually un-useable.
Old 08-14-2010, 08:05 PM
albee1952 albee1952 is online now
Default Re: Lost Communication With Audio Interface -6097
Are you certain it isn't the dreaded power harness issue? If its the mixer version, try Stand-Alonemode to see if it functions that way(if not, then its the power harness). Always try another firewire cable as they do go bad for no apparent reason(learned the hard way).
Old 08-15-2010, 09:34 AM
I checked the greed LED's in the back of the DIGI 002, and they both look right (one is blinking, one is on constantly), so I don't think it's the power harness.
Old 08-15-2010, 03:22 PM
I ran the Pro Tools Plug In List Generator, and it says:
"Plug-Ins Unused Versions
__________________________________________
BF Essential Tuner.dpm
8.0.0, Copyright 1991-2008 Digidesign, A Division of Avid Technology, Inc.
Dynamics II.dpm
EQ II.dpm
Funk Logic Masterer.dpm
8.0.0, Copyright 1991-2008 Digidesign, A Division of Avid Technology, Inc."
I cannot find these plug ins in any plug-in folder. how do i delete/uninstall these?
Old 08-15-2010, 03:26 PM
smfelton's Avatar
smfelton smfelton is offline
/Library/Application Support/Digidesign/Plug-Ins (Unused)
 OSX 10.11.5, PT 12.5, iConnectAudio4+, Axe FX 2 XL+, Music Man Majesty
Old 08-15-2010, 03:40 PM
thanks, but there is no Digidesign folder in my Application Support folder
Old 08-15-2010, 03:43 PM
The Dougfather The Dougfather is offline
You need to go to the library in Macintosh HD, not your home folder.
iMac i5 2.8GHz, Macbook Pro 2.4GHz, Pro Tools 10/11, MOTU 828mk2, Presonus Digimax FS, Presonus Firestudio Project, TC Konnekt 24D
iCON Photography
Old 08-15-2010, 03:47 PM
oh ok. thanks. do you know why that folder didn't show up when i did a search?
Old 08-15-2010, 03:58 PM
Well, I removed those plug-ins, and apparently that wasn't the problem. Because I'm still experiencing the same issues as before. I'd also like to add that my Power Mac is a 3rd generation Dual 2 GHz PowerPC G5. I haven't tried a new firewire for the DIGI 002 (because I don't have an extra that's long enough), but I don't think that's the problem because it was working fine immediately prior to upgrading to LE 8.0. But maybe I've ruled that out prematurely. Thanks for everyone's help. any other ideas?
Old 08-15-2010, 05:51 PM
Also, I've noticed that some sessions work just fine. My problems seems a lot like the problem described in this thread:
http://duc.digidesign.com/showthread.php?t=268254
however, I currently have NO non-digidesign plug-ins installed, whatsoever. Every plug-in that is currently in my plug-ins folder came with my Pro Tools LE 8.0 installation. This is just really frustrating because I just spent $120 upgrading my OS so that I could spend another $150 to upgrade Pro Tools, and now it doesn't work as well as it did when I was running 7.4.
If I have to live with this the way it is, maybe I can find some work-arounds by using more Audiosuite plug-ins. But let me ask you this, DigiTechSupport: If a fix is coming, do you have any idea when to expect it?
Lost Communication With Audio Interface -6097 Zoduati 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 03-20-2012 07:07 PM
(-6097) Lost communication with the audio interface. help!!!! ninjin 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 50 05-06-2010 02:24 PM
(-6097) Lost communication with the audio interface Kroger 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 6 12-28-2009 11:25 AM
Lost communication with the audio interface -6097. ptuser1 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 06-19-2009 02:46 PM
Lost communication w/the audio interface (-6097) Meko511 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 6 12-31-2007 12:39 PM
