PT plays MIDI input even if not assigned to a track
I use a Roland RD600 kbd and a Roland TD12 drum module, both as MIDI sources.
What happens is that PT sends both channels, regardless of my I/O assignments to the same soft synth. For instance, if I have a stereo AUX channel with Sampletank, and I don't even assign the RD600 to any MIDI channel input, it still plays on Sampletank. Same with other soft synths, so the problem is not Sampletank. I don't understand why PT takes any MIDI input and assigns it to my sunth, regardless of my I/O assignment, or lackthereof. Thanks
Digi002 Rack Mac Pro 8-core 3Ghz 8gb RAM 3X 500GB 7,200 SATA DRIVES OSX 10.5.7 PTLE 8.0cs3 |
Re: PT plays MIDI input even if not assigned to a track
HAve you checked whether 'local control' is turned 'off' on your MIDI device?? If it is not it needs to be. Local control means it recieves on 'all' MIDI channels. Once 'local' is off the MIDI device can act as a 'Multi' device rather than an 'omni'.
A
I Love Audio!!! |
Nut'n to do with local... It will play the 1st midi instantiate u have open no matter what...Its a setting in preferences... Just cut the Midi Thru off...
Cheers for the correction!!
I Love Audio!!! |
Selected instrument track plays all MIDI ins ??? | jeroen303 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 08-01-2010 10:54 AM |
Probably a stupid question but... Midi plays back track fast in parts... | Superslinky | MIDI | 1 | 10-20-2008 01:33 PM |
Play on a MIDI track while a song plays | batchmister1 | Pro Tools M-Powered (Win) | 2 | 04-12-2006 08:45 PM |
> HD - Audio leak thru track w/ no voice assigned | Howardk | Pro Tools TDM Systems (Mac) | 0 | 02-22-2006 03:00 PM |
Arming midi track!! everything plays out of time!! | crizdee | Pro Tools TDM Systems (Mac) | 1 | 02-24-2005 03:31 AM |
