Old 02-18-2009, 08:32 AM
edgarbc1 edgarbc1 is offline
Default Ramping a Tempo Change (interpolation or discrete tempo points)
When trying to have a ramped tempo increase,
say 120bpm to 140 bpm, over 4 bars, it looks like
the tempo ruler does not allow an interpolation between
120 and 140.
its seems like within those 4 bars, I have to program
discrete tempo changes gradually ramping up the tempo
at these discrete points.
Am I missing something or does the tempo ruler allow interpolated
tempo values (within a ramp defined by two points)
Wondering if i am not seeing something within PT.
tia!
Edgar
17" MBP i7, 4GB RAM, Profire 2626, PT-MP 8
Old 02-18-2009, 12:08 PM
Jenk2k Jenk2k is offline
Default Re: Ramping a Tempo Change (interpolation or discrete tempo points)
I would ramp it up measure by measure. 120-140 is 20 BPM if its over 4 bars, then increase it by 5pm each bar. I don't know of any other way to do it. if you want to get it more linear, then ramp it up every two beats instead. As long as the drummer can feel through it, you can even do it without a click if you had to.
We don't have the user centricity. Until we understand context, which is way beyond presence — presence is the most trivial notion, just am I on this device or not; it doesn't say am I meeting with something, am I focused on writing something. [LIST][*]Bill Gates .NET Briefing Day Speech (24 July 2002)
Old 02-18-2009, 12:31 PM
daeron80 daeron80 is offline
Yeah, it's point-to-point. Makes sense in that the computer must be able to know at any given moment how many samples equal one beat. For drawing w the pencil tool, you can select the desired density of points drawn at 50, 100, or 250 ms. That's in the tempo editor on the left - "Dens:" After drawing the line(s), you can add as many more points as you want individually with the pencil. Kinda tricky but not too bad. And don't forget the parabola and S-curve pencil shapes - those can feel much more natural than a straight line sometimes.
David J. Finnamore
Nyquist was right.
PT 2019.10 Ultimate | Omni | macOS Sierra
PT 2019.12 | Saffire Pro 40 | Win10
Old 02-18-2009, 12:55 PM
Stig Eliassen's Avatar
Event (menu) -> Tempo Operations
Make a selection, and set the ramping to any shape you like. You can also change the density in this window.
Doesn't that work for you?
Tempo change causing midi volume to change plugin output tgrfox 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 08-05-2011 01:08 PM
Need to Change tempo but without changing existing midi data tempo? Einsteinwannabe Pro Tools M-Powered (Mac) 2 09-18-2010 06:58 AM
REX tempo Change ozzi 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 11-12-2006 11:24 AM
Tempo Change w/out moving other tempo changes pietro79 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 02-20-2006 09:00 AM
Tempo change without pitch change for audio layman 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 03-16-2002 07:14 PM
