Old 10-28-2015, 08:34 PM
SupreGlu SupreGlu is offline
Default Re: set automation point at exactly zero
working for what?
Old 12-14-2015, 01:19 PM
so no key command to constrain automation point to zero?
Old 12-14-2015, 02:12 PM
elicious elicious is offline
hmmm... surprised no ones mentioned
cmd-/ (on a mac)
sets the auto point at whatever value your fader is at
and at the current timeline position.
so first clic on the auto param you want to edit,
at the preferred spot,
then opt-clic your fader to zero
and cmd-/...
e
ihatetyping
Old 12-14-2015, 02:38 PM
amagras amagras is offline
Voted. I only move automation in groups with ctrl to avoid this.
amagrasmusic.com
Old 12-14-2015, 06:24 PM
cmd-/ (on a mac)
and cmd-/...
e
command forward-slash does not seem to do anything in volume automation playlist
Old 12-14-2015, 08:56 PM
how is this done?
Old 12-14-2015, 09:56 PM
make sure your cursor is on the line,
and within any auto lane
cmd-/ will drop a breakpoint representing the current value…
e
ihatetyping
Old 12-15-2015, 05:20 AM
joachim's Avatar
joachim joachim is offline
, if you have HD.
And it will produce nasty 2 breakpoints at the same time (the old value and the 0 value).
PT 11.3.2 HD , RME Fireface 800 , Genelec 5.1 ,
Win7 64bit Professional , i7 3930 Hexcore , 48GB Ram , SSD System + SSD PT Session/Audio + SSD Video (all Samsung 840 Evo) + Spinner 1TB Data , 2x Radeon HD 5450 \\ SD 633 Femto MKH8060 MKH8070 MKH30/MKH40 DPA4060
Old 12-15-2015, 03:03 PM
nope; single breakpoint
…unless you make a selection,
then you get 2 right where you want them…
e
ihatetyping
Old 12-16-2015, 05:02 AM
joachim's Avatar
Not on my system :
Screenshot 1 : automation line, not static, not at zero
Screenshot 2 : insertion, alt-click fader, jumps to zero
Screenshot 3 : write-to-current, result : the mentioned 2 breakpoints
Even with a static 0 db automation line; alt-click fader at insertion and write-to-current will produce 2 breakpoints at same point in time : the old value 0 and the new value 0. Drag the visible one to a side - the second will remain at the position.
The above is valid for PT 11.3.1, maybe it is different in 10.
Four-point automation w/fades? bleen macOS 1 02-22-2014 05:47 PM
Move Automation to Sync Point quoid macOS 2 02-26-2011 10:11 AM
Key-Command for dropping automation point? Floydio Tips & Tricks 9 05-11-2009 04:56 AM
Automation point resolution Centurion Pro Tools TDM Systems (Mac) 1 01-20-2003 08:58 AM
Automation point moving Sparks 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 12-22-2002 03:46 PM
