TL Space Impulse Responses won't load
I have installed 4 different versions of TL Space Native and The impulse reponse library cd won't show up (after installing), and I can't install the downloaded impulse responses either. Any ideas on what I should do?
Re: TL Space Impulse Responses won't load
Are you installing the impulses from inside the plug in window? I had to install all of them 1 by 1, because the download has no impulse installer.
Yeah. When I use the window in por tools it says that there is an error installing the impulse response. When I install the cd I don't get any error messages but no impulse responses show up in the TL Space interface. This is true for the 4 different versions of TL Space I have tried installing.
Hi Bart,
you could try the following: In the TP Space Window, go to "Edit" and then "Import other IR folder". Point it to the directory you installed the library in. This worked for me... Cheers, Andy |
Btw, for me the cause of the problem was that the installer put the libraries in the wrong path...
TL Space Native - no impulse responses will load | Hobson | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 14 | 02-16-2010 11:22 AM |
Recording Impulse Responses for TL Space | postprosound | Post - Surround - Video | 2 | 05-31-2007 12:11 AM |
TL Space Impulse Responses | GuyPicks | Pro Tools TDM Systems (Mac) | 4 | 01-26-2007 06:58 PM |
TL space- Impulse Responses | bmuth | Pro Tools TDM Systems (Mac) | 3 | 11-07-2005 10:09 PM |
